RV.Net Open Roads Forum: Technology Corner: Internet Service While RV'ing
 > Internet Service While RV'ing
Time-to-travel
Canada
Posted: 05/05/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Great ideas and resources. Thanks everyone!
MVG3D
Elizabeth Colorado
Posted: 05/05/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Verison air card $60 a month. Works great.
Enjoying the Lagniappe
Destin,FL,US
Posted: 05/05/08 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
We use the wi-fi at the campgrounds.
BackroadNiagraFamily
Phoenix AZ
Posted: 05/05/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
After reading through this thread I actually looked at my Sierra Wireless Aircard 875 (Cingular/AT&T Service) for my laptop and noticed that there is indeed a port for an external antenna. At the risk of covering old ground: Do the external antennas help? Is there a preferred model/manufacturer or setup for such an antenna? Anything I should avoid?
Thanks.
judy&frank
Seattle, WA
Posted: 05/05/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
We use a Sprint broadband modem and Cradlepoint Router to support our 2 laptops and server. Go to 3GStore.com for expert advice and service. We have been very happy with our service, camping at state parks and National Forest campgrounds all around Oregon.
Judy and Frank and Missy (purr-person)
2001 Ford F-250 4X4 Powerstroke 7.3L Extended Cab Long Bed
Crossroads Cruiser 28RL double slide 5th wheel
garym114
Posted: 05/05/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
External antennas will give you a stronger signal. You will be able to connect in weak signal areas and and in places you had no signal at all previously. Wilson electronics has antennas for magnetic mount and roof mount. Since there is no standard for the antenna connectors there are several types. Wilson has adapters that connect their antennas to your external antenna connector. The adapters are about 12 inches long and end in a female antenna connector. So, get an antenna that ends in a male connector.
It can be as easy as putting a magnetic antenna on top of a truck or permanently mounting an antenna on the roof of the RV.
2000 Sea Breeze with 1998 CRV Toad in Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
