RV.Net Open Roads Forum: Fifth-Wheels: GFI Electrical problem
 > GFI Electrical problem
Njmurvin
Simi Valley
Posted: 05/05/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
As I understand it, my GFI protects my bathroom outlet (where the GFI plug is), the outside plugs, the one over the kitchen sink and (in my rig), the lower living room plug on the other side of the RV door (I have a center kitchen). The latter plug is GFI protected (I assume) due to its proximity to the sink.
Now that the stage is set. My GFI breaker kept popping. So, I started tracing. I got to the kitchen outlet where 3 sets (each set a hot, common and ground) of wires join at the receptacle over the sink. One set was hot and the other two obviously went on to other outlets. I put my ohm meter on them and discovered that one set of wires was shorted between the common (white) and the ground (bare). When I joined the other two sets of wires (leaving the shorted set out), all circuits were hot and the GFI stayed on EXCEPT for the living room outlet on the other side of the door. I pulled that outlet (hoping the short was in there) but no such luck. Again the common went to ground on that wire.
My conclusion is that either (1) there is some device or something in between those two outlets where the short is happening or (2) there is a short in the wires themselves somewhere in the romex run between the outlets. I recently had a new roof put on. My fear is that the wire going over the door to the wall outlet might have caught a nail, staple or screw.
I am not opposed to just killing that outlet. The only thing we ever use it for is the vacuum. But, I'd like to keep it if possible.
Thoughts?
2004.5 Dodge 3500 4x4 Laramie SWB QuadCab CTD, 48RE (auto), Putco Boss Bars, Pullrite Superglide, LineX, Prodigy
1994 Terry 305 31' Single slide
Vulcaneer
Northern New England
Posted: 05/05/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Njmurvin wrote:
(1) there is some device or something in between those two outlets where the short is happening. Thoughts?
Are there other outlets on this circuit? Maybe for LR orBR tv's? Do they all function correctly? Have you tried running a set of test wires directly from the Kitchen to the LR outlet that is a problem? Does that help it work without tripping the GFI?
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
Quint Da Man
Peabody, MA
Posted: 05/05/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
You might want to check your wiring diagram. At some point, typically at the power distribution or circuit breaker box, the common is tied to ground.
2008 Cedar Creek Silverback 30LSA
2007 Chevy Silverado 2500HD D/A
4Kings
NE Missouri
Posted: 05/05/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I had a bad GFI outlet, caused me weeks of frustration until an electrician friend suggested I change it out. Haven't had a problem since.
2003 Chevrolet 2500HD, CC, SB, 6L, 4.10, Auto, 4x4
2005 Wildcat 27BHWB, RBW 15K, Prodigy, TTT Mirrors
davidj54
South Alabama
Posted: 05/05/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like there is a short caused by the new roof installation. You could possibly back out a screw or two in the area of the wiring and test to see if that clears the short. If it does it might be possible to tie a new wire to the old wire and fish it through. If it is a screw be sure to use a shorter one if you're lucky enough to fish a new wire to replace the old one.
I've seen screws and nails pierce wiring & plumbing lots of times. That's why building codes require protectors over wiring and plumbing in walls now.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
skipnchar
Topeka Kansas USA
Posted: 05/05/08 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Most RVs have at least TWO GFI circuits inside, with the exception of some smaller units. All of your outlets should be on one of the two circuits. I'd do some mapping and find out where all of the outlets are wired to before making any changes. Good luck / Skip
Njmurvin
Simi Valley
Posted: 05/05/08 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. Here are my answers/comments:
I tested all other outlets. Only the lower LR outlet nearest the sink is dead when the wire causing the GFI trip is taken out of the loop.
I don't have a wiring diagram. I looked thru all the paperwork that came with the trailer.
The GFI outlet works fine as long as the wire going to the trouble outlet is disconnected. And, there is a short from common to ground on that wire. I assume that short is causing the ground fault. If so, the GFI breaker is doing its job.
My manual only mentions one GFI circuit and there's only one GFI breaker. Everything functions with the GFI off except those locations mentioned.
I wondered about common normally going to ground. But, if common is supposed to go to ground, then I would expect the other two sets of wires to do so as well. They don't. So, I still think this is the source of the short.
I really suspect the roof install as the culprit. This all started right after the roof install. In order for the wire to get from the kitchen to the LR outlet, it has to go over the top of the door. I suspect it caught a nail/staple/screw up there and shorted it. I will probably just kill the outlet (put a cover over it) unless I can find 110v somewhere to run it under the trailer and up the wall to the outlet. Otherwise, there would be no hope in pulling a new wire in place of the old one. The offending staples, etc. would be covered by the new roof rubber. So, that's a lost cause.
Thanks, everyone, for your suggestions.
jeaelectric
knoxville
Posted: 05/05/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
because it is a gfi you could just leave the ground off and that should work fine.
2004 PS Ford F-350 DRW
2007 S.B. Bristol Bay 3420BH
Samque
Coalfield,Tn.
Posted: 05/05/08 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Outlets have been known to get damaged or just go bad.
I would take the lower lr outlet out and check it>
2001 Chevy 2500HD D/A LT CC LB
1994 Carri-Lite Cashay
Steve&Kathryn&Miles our Bichon Frise Wonder Dog
USS Trumpetfish SS-425
Diesel Boats Forever
