RV.Net Open Roads Forum: Things Manufactures do that make you go HUH?
 > Things Manufactures do that make you go HUH?
Crazy_2
New Maryland New Brunswick
Posted: 05/06/08 08:19am Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
"mickey of hooch?" Don't know that one....
"Bottle of Booze"
03 Nissan Xterra
Travel Star Sport XLT 24 FQB by Starcraft 3570 LBS Dry
Prodogy EBC, Reece Dual Cam WDH
Diabs
Toronto, Ontario
Posted: 05/06/08 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Loopy wrote:
I don't have as much of a problem with the builders as I do the designers.
Seriously, what were they thinking in some of these TTs when they put the entertainment center directly next to the couch at a 90 degree angle? I realize that was probably the only place left to put it but if it were me I'd have scrapped that design and come up with a better one.
Too funny....I always said the same thing for years, looking at layouts for the perfect entertainment center, which should be directly across from you. Not neck-bending achs for enjoyment.
But I finally found mine....
QCMan
Long Island, New York
Posted: 05/07/08 04:00am Link  |  Quote  |  Print  |  Notify Moderator
We have a friend with a Wilderness TT and the bathroom cannot be gotten to unless the slides are out. Some real brainiac thought that one out!
2004 Starcraft Aruba 25RS, 2004 Dodge Dakota SLT. Just the two of us, 2 Jacks and a desire to roam!
nosaint3
Sioux Falls,SD
Posted: 05/07/08 04:31am Link  |  Quote  |  Print  |  Notify Moderator
My Fleetwood bounder has a nice deep storage area with three shelves that had a door that wouldn't open over four inches with slides out. It was blocked by a decorative block of wood over the bed. Warranty solution was to remove the block on that side. Works fine now and I don't even miss the block of wood. Another sleepy designer I guess.
nosaint3
symbasden
WI
Posted: 05/07/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
I have an outlet ON BOTH SIDES of the bed that you can barely get to, I agree real smart guys!
Jeff
2009 Rockwood Signature Ultra Light 8317SS
2004 Dodge Ram 1500 QC LB Hemi
DW Kelly and DD
Opie431
Bellevue, MI
Posted: 05/07/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Instead of putting something in to hold the same screws, buy better screws next time and replace them. The ones on the outside of our trailer have begun to rust so I assume the inside ones could also.
goodolejayco
Middlebury, IN
Posted: 05/10/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
what most retails don't understand is that there is a great deal of what is called "shake down". when you buy a new trailer when it goes from the production the shake down occurs. The unit goes down the road from point A to point B and things litterally shake loose. Plumbing,trim and so on. If you want a bug free unit buy a 2 to 3 year old trailer well maintained and you be a great deal happier with alot less peoblems.
