RV.Net Open Roads Forum: Fifth-Wheels: tires for my 5th wheel
 > tires for my 5th wheel
ednmissb
florida
Posted: 05/05/08 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking for tires for my 5th wheel trailer. manufactor recommendations call for a size 235/85 r16 load range E. I am looking at a uniroyal 235/85r16 uni lar awp 118q which is a truck tire or a goodyear Wrangler RTS 235/85 R16 load range E. This is also a truck tire. Both dealers say these tires are good for RV use and will hold up well. Has any body used these tires with good results, or would some one reccommend a different tire. We average 10-12 thousand miles a year with our camper. thanks ED
pulsar
Lewisville, NC
Posted: 05/05/08 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
SH
Lynden, WA
Posted: 05/05/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I am not lucky enough to be able to use 16 inch...must stay at 15. However, pretty hard to beat the proverbial Michelin XPS if your buying 16 inch tires. Pricey! Over $200 each!
2003 Springdale 279
2007 Chev 2500 LMM Duramax/Allison
1993 Heritage
1989 Sporty
Dennis Bham
Alabama
Posted: 05/05/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Michelin XPS Rib or BF Goodrich Commercial TA All Season ...
I have the BFG's and am happy with them ...
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
funtogo
Amory,Ms.38821
Posted: 05/05/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Just got the B F Goodrich Commercial T A for my cardinal. I used the LT245/75/R16E,which was closer to my tire size of 235/80/R16.
2006 Cardinal 30TS
2006 Chevy 2500HD CC 4x4 D/A
wayne_tw
South Dakota/Georgia
Posted: 05/05/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
My Trailer came equipped with Uniroyal Laredo tires. Knock on wood, so far so good.
rob85546
Hot arizona
Posted: 05/05/08 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Maxxis, good price, good tire
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
gitane59
Ontario, Can
Posted: 05/05/08 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
With your mileage of over 10k miles per year you could not go wrong with the Michelin XPS Ribs. look at their specs and compare them to other identical sized and rated tires and you will fnd that the XPS Ribs weigh about 8lbs heavier than any other tire of the same size and rating. they really are the strongest. Just put a set on my 5ver about a month ago.
$230 each Canadian installed and balanced.
2001 Newmar Kountry Star 34BLDS
2001 Ford F350 CC SRW V10 4.30LS
Capitulation is not Reasonable Accommodation
Sundowner1
Chesapeake, VA
Posted: 05/05/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered my 1999 and 2001 Fleetwood Terry 5th wheels with the Goodyear RTS tires, and never had a moments trouble with them.
Sundowner
04 Chevy 2500HD, Duramax, ext cab, short bed, 4X4
08 fleetwood Quantum 325RKTS (I put Bridgestones on this one), got a good deal on them, otherwise it would have the Goodyears.
JIMNLIN
Big Cabin, OK
Posted: 05/05/08 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
ednmissb wrote:
(snip)
(snip)
thanks ED
ED
as others I would recommend the B F Goodrich Laredo Commercial LT E over the Laredo AWP. I have them on my 5er and a implement trailer. The 5ers are going on 6 years.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
