RV.Net Open Roads Forum: Tech Issues: Onan Microquiet 4000 Won't Start
 > Onan Microquiet 4000 Won't Start
Dshort
Bremerton, WA
Posted: 05/05/08 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I just completed a "tune-up" on my genset, Now it won't fire. I had replaced the oil and Sparkplug and air filter.
My tank is full, the fuel pump is pumping... I took the fuel line at the carb off and pressed the start switch.. fuel gushed...
I've tried starter fluid is only a slight change is symptoms.. it fires once or twice (Cycles) then nothing...
This genset ran fine prior to the tuneup.. now squat?
Any clues?
Model is 4KYFA26100A
Where can I find a manual online... ?
thanks.
ozman
Ma.
Posted: 05/05/08 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Are the plugs gapped right.I know some come pregapped,but you should check for spark.You should check to see if you knocked a wire loose somewhere also.
roadrunner16
Tucson
Posted: 05/05/08 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same thing happen to me. It was just that the oil was low. If the oil is low it will not start.
trnfla
Tampa
Posted: 05/05/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
2nd to check your oil level and the wire on the oil sending unit to make sure you did not pull it loose.
Have a great time camping,
Terry
Please say a Prayer for my 10 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
kg5388
memphis
Posted: 05/05/08 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
stick the old plug in the plug wire and hold it to the block with some pliers and see if it fires then stick the new plug in and see if it fires the new plug could have been dropped at some time or another between being made and when it was sold
if your plug wire is connected to the blue box make sure you didn't knock the white wire off
1995 viking pup
1988 four winns 160 freedom boat
Onan RV full service certified
level 2 onan industrial gen tech
comfortguard APU full service certified
onan portable full service certified
onan RV hybrid full service certified
Dshort
Bremerton, WA
Posted: 05/06/08 12:35am Link  |  Quote  |  Print  |  Notify Moderator
I checked the Oil.. it's middle of hash marks, I do have spark when the old plug is connected to the wire and held near the frame.
I did not see any loose wires, where is the oil sender located? it would be a lot simpler if it wasn't under an RV!
jenks60
MS. coast
Posted: 05/06/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Did you check BOTH plugs for spark?
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
Dshort
Bremerton, WA
Posted: 05/06/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I hope your asking if I checked both old and new plugs.. Yep, I did just now add a bit more oil to answer another line concern. and it fired up, but is throttling and then dies, mayhap's too much oil now.. but the stick still reads in the hashed level.. should I drain it again and measure out 1.7 quarts. just how sensitive is this oil sensor? and is it a hi/lo or just lo?
jenks60
MS. coast
Posted: 05/07/08 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was asking if you checked both plugs, the one on the front and the one on the rear? You could have a choke problem, or a carb adjustment problem.
BUT, I am not a Gen. Tech.!
Good luck.
Generator Jim
Conway, SC
Posted: 05/07/08 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
A Micro Quiet 4000 only has one spark plug.
The oil level switch is only low, not high/low.
ONAN did away with the level switch on the later models and published a PSB (Product Support Bulletin) to unplug the switch on the earlier models. Just check the oil before each use until you have an idea of the oil consumption, if any.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
