Dshort
Bremerton, WA
I just completed a "tune-up" on my genset, Now it won't fire. I had replaced the oil and Sparkplug and air filter.
My tank is full, the fuel pump is pumping... I took the fuel line at the carb off and pressed the start switch.. fuel gushed...
I've tried starter fluid is only a slight change is symptoms.. it fires once or twice (Cycles) then nothing...
This genset ran fine prior to the tuneup.. now squat?
Any clues?
Model is 4KYFA26100A
Where can I find a manual online... ?
thanks.
ozman
Ma.
Are the plugs gapped right.I know some come pregapped,but you should check for spark.You should check to see if you knocked a wire loose somewhere also.
Frankie
Karen
3 boys and Amber and Capt. Jack our JRT's
2006 FOUR WINDS HURRICANE 34N F-53
2003 SUZUKI XL-7
2000 WRANGLER
Thor and Fourwinds hurricane forum
roadrunner16
Tucson
Had the same thing happen to me. It was just that the oil was low. If the oil is low it will not start.
trnfla
Tampa
2nd to check your oil level and the wire on the oil sending unit to make sure you did not pull it loose.
Have a great time camping,
Terry
Please visit my Photos and Blog NiceCamps.com
New (2 me) 2004 Winnie 31C
2006 Expedition EB, replaced by scooter and 2008 Mazda 3
Had 2007 Zeppelin EZ190, Prodigy, Equalizer
kg5388
memphis
stick the old plug in the plug wire and hold it to the block with some pliers and see if it fires then stick the new plug in and see if it fires the new plug could have been dropped at some time or another between being made and when it was sold
if your plug wire is connected to the blue box make sure you didn't knock the white wire off
1995 viking pup
1988 four winns 160 freedom boat
Onan RV full service certified
level 2 onan industrial gen tech
comfortguard APU full service certified
onan portable full service certified
onan RV hybrid full service certified
Dshort
Bremerton, WA
I checked the Oil.. it's middle of hash marks, I do have spark when the old plug is connected to the wire and held near the frame.
I did not see any loose wires, where is the oil sender located? it would be a lot simpler if it wasn't under an RV!
jenks60
MS. coast
Did you check BOTH plugs for spark?
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
Dshort
Bremerton, WA
I hope your asking if I checked both old and new plugs.. Yep, I did just now add a bit more oil to answer another line concern. and it fired up, but is throttling and then dies, mayhap's too much oil now.. but the stick still reads in the hashed level.. should I drain it again and measure out 1.7 quarts. just how sensitive is this oil sensor? and is it a hi/lo or just lo?
jenks60
MS. coast
I was asking if you checked both plugs, the one on the front and the one on the rear? You could have a choke problem, or a carb adjustment problem.
BUT, I am not a Gen. Tech.!
Good luck.
Generator Jim
Conway, SC
A Micro Quiet 4000 only has one spark plug.
The oil level switch is only low, not high/low.
ONAN did away with the level switch on the later models and published a PSB (Product Support Bulletin) to unplug the switch on the earlier models. Just check the oil before each use until you have an idea of the oil consumption, if any.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
