RV.Net Open Roads Forum: Towing: Is this set up right?
Search only in Towing
Open Roads Forum  >  Towing
 > Is this set up right?
LoudRam
New Jersey
Posted: 05/05/08 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I hooked up my TV to my TT for the first time today. I'm using the the "equalizer" hitch. Does this look right?
My measurements were as follows...
TV alone front...38 3/8" back...40 7/8"
TV w/TT on ball alone front...38 1/4" back...38 1/4"
TV w/TT and WD front...38 1/4" back...38 3/4"
BTW... The measurements were from the ground to the top center of the fender as per the instructions.
* This post was edited 05/05/08 06:42pm by LoudRam *
Todd
Desert Storm Vet (US Navy)
2002 Fleetwood Prowler Lynx 30'
2001 Dodge Ram 1500 Quad Cab 4X4 w/360 (not stock)
Predator DX2 brake controller
Equalizer Sway Control Hitch
If you can read this thank a teacher
If you can read this in english thank a vet
Kenneth
Washington, the state
Posted: 05/05/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Remeasure. It would be very unusual for the front end of the TV to be higher unhitched than it is hitched without the w/d.
You want to get the spring bars tight enough so the front drops a bit and the rear drops equally or a bit more. Level the trailer with the position of the hitch head on the hitch shank. Provide 5 or 6 links of chain under tension (for room for movement when turning) by adjusting the angle of the hitch head.
LoudRam
New Jersey
Posted: 05/05/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm taking it out again Friday. I'll have to double check the measurements. I thought something didn't look right. Thanks
Chuck&Gail
In the Colorado Mountains
Posted: 05/05/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
IMO you need to add a washer in the head if it is an Equal-i-zer hitch.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
LoudRam
New Jersey
Posted: 05/05/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
There are 5 in there now. Maybe raise the L-brackets up one hole?
BarneyS
S.E. Lower Michigan
Posted: 05/06/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
You can put as many as 8 in there if I recall correctly. You want the spring bars to be level with the L brackets. If you raise the L brackets, make sure the bars are not pointing upward. Better to tilt the hitch head to get more tension if the bars are level now.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/06/08 08:51am Link  |  Quote  |  Print  |  Notify Moderator
From those numbers, it appears the weight distribution bars are not doing anything, as no heights changed between them being unhooked and and hooked up.
It does sound strange that frontend went down after the trailer was hooked up but before the bars were hooked up.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
mkirsch
Rochester, NY
Posted: 05/06/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I'll bet it's a typo or misread. It's probably 39-1/4", not 38-1/4".
LoudRam
New Jersey
Posted: 05/06/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
I just re-measured my truck empty.
The front is 38 1/8" (old measurment was 38 3/8") Maybe I did measure wrong yesterday.
The back is the same.
If I did get it wrong yesterday and it was 38 1/8" then everything is starting to make more sense. When I hook it up Friday I'll re-measure everything again.
Overall I think the fact that my truck only squatted down 2 5/8" with a 30' TT w/o a WD hooked up is pretty good for a 1500.
Mar-d-mar
Blue Springs, MO
Posted: 05/06/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Can someone please explain the "washers in the head" of an equalizer thing? We have an equalizer, and when the hitch is in, and the camper not hooked up, it rattles like there is extra room somewhere. Is that where the washers idea comes in?
Also, we are headed to Yellowstone from KC. I am worried that the whole hitch thing isn't perfect, and that we'll be sorry on the trip. Does anyone have details that I could check out my setup to make sure we will be OK?
Thanks in advance!
