RV.Net Open Roads Forum: Technology Corner: converters
 > converters
ggrotz
san mateo,ca
Posted: 05/05/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I hooked the [analog to digital] converter up to my tv in a conversion van,using an inverter,and the picture broke up and eventually was lost.Some of the channels pictures had a one inch border around it.This converter was an insingna from best buys.Next I hooked a Magnavox [from walmart] to a tv in the house with rabbit ears and it did exactly what the converter did in the van.I ask a clerk at radio shack and he said it was to early.
2oldman
WA
Posted: 05/05/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
glad you got it solved
Golden_HVAC
Fulltime, CA, USA
Posted: 05/05/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you bought a defective converter box.
You should have some sort of on screen display to program the box. But at the minimum there should be a way to program the box for your local HD channels.
Do you know anyone else with a HD set in your area? You can find out how many HD channels are out there. Every month or two, more HD stations come online.
It is possible that you live in an area with no HD stations. But the San Jose area should have over a dozen HD stations running right now. If the converter box is not picking up any of them, then return it and get another brand or at least a box that has been tested.
Because the retail price of these things is limited to only about $45, they probably only cost Best Buy $12 - $14, and the manufacture has to build them for less, so the distributor can take $3 profit too.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach
If there's a WILL, I want to be in it!
You meet the kindest people at RV Rallies. 21 rallies so far
I havn't been everywhere, but it's on my list
Escapees
Trailering Texans
Huntsville, Texas
Posted: 05/05/08 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Digital signals are different from analog. When the analog signal gets weak you can still watch it even if the picture is bad. With Digital if the signal gets weak it pixelates out and then just goes blank. Try going to your "menu" and chose a SCAN function. Scan for channels in your area. I would think an urban area would have several by now. My converter also has a choice of regular or "letterbox" - that might cause the border at top and bottom ??? You might hook up to an antenae and do the SCAN function. You need a clear path for your signal - NOT in a basement, etc. If that doesn't work I would take the unit back and try another.
Wherever I happen to park
Posted: 05/05/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
You have.. I very strongly suspect,,, A MODIFIED SINE WAVE inverter
I keep saying they cause television interference. And so they do.
Try a true sine wave I plan on trying one Tomorrow. However it may take me a day or two to try the Insignia on the TSW
jauguston
Bellingham, WA
Posted: 05/05/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
yxm,
Do you suppose his power company is giving him MSW electricity to his house???
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
 > converters
