LMSM1244
Savannah, Ga
I have been using my blue tote now for about a year and half. The wheels that came with it are starting to look rough along with that I can be heard throughout the campground when going to the dump station and with the wife and two small girls that is quite often. Anybody have a modification to the tote for better wheels and to make it quieter?
Thanks
fla-gypsy
North Florida
Many forum members have replaced the stock tires with pneumatic tires. Some of them will be along after while to post pics for you.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
JJBIRISH
BUTL;ER, PA, USA
a couple of 4" pneumatic wheels from tractor supply ($4) and a longer axle rod and 4 push nuts to hold the wheels in position... quieter and easier to pull with the ball bearings...
just remember you will have to be able to stop quick if you get a flat though, you can wear a hole in the tank in a very short distance when its loaded...
you can use almost any old lawn mower wheels to replace a bad wheel...
(the larger the wheels, the higher the tank, the high the plumbing will need to be)
Love my mass produced, entry level, built by Lazy American Workers, Hornet
robbie69
wauconda, il usa
haven't done it yet but will replace mine with the lawn mower hard rubber ones. thought about the air ones but haven't seen any small eunf for the 2 in front that steer-they are underneath in the front so clearence would be a problem i think.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
2manytoyz
Central FL
I have one also, but haven't had need of it yet. I did buy the tow handle, but the wheels leave a lot to be desired.
Rather than modify the tote, have you thought about simply strapping it to a handcart?
$26 at Harbor Freight:
This picture shows the cart laying down. The handle can be reconfigured to use it up right. Slight modification so it can be attached to a hitch. Scoop up the blue tote, tip the handcart back, connect it to the hitch. Handcart folds up fairly small when not in use. Might be a cheaper, easier alternative, to modifying the cart.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32410
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
BrokenElbow
Valencia, CA
I changed the rear tires on my 32 gal blue tote.
I used the 10" pneumatic tires from Harbor Freight. Tires. I used the same axle and put new axle caps on the ends from the local hardware store.
I think I will also replace the front tires with the 4" pneumatic tires mentioned in this thread.
2006 Cougar 294RLS TT - 2008 F350 Lariat 6.4L diesel 4x4 SRW SB. Reese WD w/HP Dual Cam, 2xHonda 2000i,Rotochoks,Levelairs,Toppoprails bike rack
LAdams
Northern Illinois
Here is a picture of my Barker with the HF 10" Pneumatic wheels installed... In this picture the Blue Boy is mounted on the rear bumper of my previous Nomad 27 footer...
I used the existing "Blue Boy" axles and just drilled the axles for cotter pins using flat washers on each side of the wheel...
Here are the wheels
And here is the link to the HF website
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=30900
The "Blue Boy" is now carried UNDERNEATH our 31' Nomad TT on a special mount that drops down with the removal of 2 hitch pins...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
Mamzerook
Okanagan B.C.
as a quick fix you could wrap duct tape around the plastic wheels. I did this to increase traction on my kids power wheels and it quieted them down on the gravel and concrete as it made a cushion
1995 K3500 Silverado 6.5l TD
2008 Jay Flight G2 27BH
michcruiser60
Michigan Water Wonderland
Nice work on the blue tote Les. Looks like it rides under there with no problems.
2001 GMC Sierra 2500HD 8.1/Allison 4x4
1964 Ander-ett 16' TT
Please check out my profile...
"The camera always adds 10 lbs. So the trailer's not over weight."
javaseuf
Southern Cal
LAdams wrote: Here is a picture of my Barker with the HF 10" Pneumatic wheels installed... In this picture the Blue Boy is mounted on the rear bumper of my previous Nomad 27 footer...
Here are the wheels
Les
Les,
I never tire of viewing the great mods that you have done!!
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
