ffemt1271
Louisiana
you should try fluid film www.eurekafluidfilm.com available also at john deere dealers. go to thier site and read about it. it does exactly as they advertise. thats what i lube my jacks and slide system with
Professional Firefighter/EMT
2003 DODGE 2500Hd/ cummins
2001 dutchman 27rk 5er
Prodigy Controller
SH
Lynden, WA
I use whatever is handy...last time it was PJ1
2003 Springdale 279
2007 Chev 2500 LMM Duramax/Allison
1993 Heritage
1989 Sporty
Glen41
North Texas
Any dirt bike rider always has a can of chain lube. Molly-"sumthin"-di-sulfide. I can say it, I just can't spell it. Dries out and doesn't attract dirt.
Fun is that stuff that happens in between mistakes.
2006 Chevy 3500 D/A DRW Prodigy, AirBags, CoPilot, EarPlugs
34 ft River Canyon with most of the pieces still attached
Roy T
Dodge City, Kansas
I use the same silicone spray I use on the slides.
mr. ed
Madison, SD (currently traveling the US)
I use silicone spray on mine....works fine and doesn't attract dirt like grease will.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
PackerBacker
Montreal, Quebec,Canada
mr. ed wrote: I use silicone spray on mine....works fine and doesn't attract dirt like grease will.
Same here.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
MudChucker
Winnipeg Manitoba
Glen41 wrote: Any dirt bike rider always has a can of chain lube. Molly-"sumthin"-di-sulfide. I can say it, I just can't spell it. Dries out and doesn't attract dirt.
LOL, molybdenum disulfide
be care full tho, your high end chain lube will likley contain extreme pressure agents. Lube's containing extreme pressure agents must never be used were brass bushings or bearings etc are used as the agents will react with the brass.
2006 Springdale 292BHLS
2007 GMC Sierra 2500HD SLT 6.0
jspringator
Versailles, KY 40383
What about Dri-Slide?
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion LTD 3.73 LSD, V-10, 2WD
Yamaha EF2800i genset;
2000 watt Tripp-Lite inverter/charger APS 2012
12' Porta-Bote 75 6 hp Johnson
1989 Bayliner Ciera 2150
Saturn SD365 inflatable, 75 Rude 25HP
hotpepperkid
Chino Hills CA
I just use WD-40 and when they get hard to use wash them out with water and put more WD-40 on them. It not that they get real hard to lower or raise but they queak a lot and Im sure the wakes up the poor lazy people in a camp ground when I leave at 6AM. Only have to do that about once a year and we camp in the desert in the winter time and it get perty dusty at times.
hpk
2000 Ford F-350 SRW 4X4 PSD 28' Prowler 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
lat471
Lebanon, PA
Silicon or WD-40 first can I grab.
07 Cameo LXI F35FD3
R Taj-We-Haul
