RV.Net Open Roads Forum: Fifth-Wheels: Lube for scissor jacks?
 > Lube for scissor jacks?
Cabriolet86
Rochester, MN
Posted: 05/06/08 07:09am Link  |  Quote  |  Print  |  Notify Moderator
What's the best lubricant to use on my rear scissor jacks? They're locked up pretty good after winter storage. I'm thinking just a lithium grease? I've obviously heard that you don't want to use something that attracts dust.
ford truck guy
Pennsylvania
Posted: 05/06/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I wonder if the Slip Plate spray would work for that? I have always used White Lithium Grease untill I started using Slip Plate for my Hitch ????
Joe and Lori
2005 Ford F250 SD 6.0
08 Montego Bay
Kenneth
Washington, the state
Posted: 05/06/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Try some of the lubricant made for locks. Lock-Eaze is one brand...there are several. These supply graphite to the moving parts but the liquid evaporates. Grease or oil doesn't "attract" dust but does hold it when the dust blows into the moving parts.
M GO BLUE
Southgate, MI
Posted: 05/06/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Purchase yourself some dry lube so it doesn't attract dust, dirt, grime, etc.
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS
Built-In Onan 5500W generator
ryanallie1
Magalia, Calif
Posted: 05/06/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
We second the motion of useing only a Dry Spray Lube. It will keep the rust away, it won't attract dirt or dust. Use it also on your landing legs as well. It also works very well, on your Black & Gray Valves. It keeps them moving very easily. Only use grease on your King Pin itself, and your Locking arms. Also use a Teflon Disk, and use the Dry-Lube spray on both side of the Teflon Plate, and on top of your hitch plate too. No dirt or dust is alawys nice. Good Luck. Happy Camping, Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
Land Cruisers
Waterloo, Ontario, Canada
Posted: 05/06/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Go get some of this stuff;
Dupont Teflon Multi Lube
Ace hardware also carries it. You spray it on, it dries to a dry waxy finish, lubes great, and no dirt sticks to it. It's also great for lubing 5th wheel hitches, bike chains, anything else like that.
2008 Jayco Eagle 325BHS
2006 Dodge Ram 3500 MegaCab 4X4, Cummins
2 kids age 6 & 8, and a 6 year old golden retriever...
nebmike
Sterling, CO
Posted: 05/06/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I've given up on lubing stabiizers until they 'really' need it because ever time I've done so, they stop holding. What I mean is I crank 'em down and cinch 'em snug and as soon as I take the handle off you can watch the bolt loosen 1/2 to a full turn.
Maybe its just me.
__________________________________
Mike & Chris
2007 4x4 Expedition EL Eddie Bauer
2004 4x4 Super Duty Lariat 6.0L
2007 Laredo 315RL
The 3 dogs (Duncan, Dawson, Max)
chrizg
IA
Posted: 05/06/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I used A.S.T. Penetrant II when my B&W Hitch locked up. It worked pretty good.
09 Big Country 2950RK
06 Dodge 3500 CTD 4X2 Mega Cab DRW B&W
Mmaxed
Montana
Posted: 05/06/08 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Clean threads with a wire brush and lube once or twice a year with Slip Plate. It's a dry lube that will not atract dirt.
John3872
Iowa
Posted: 05/06/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use White Lithium Grease. Seems to work good and stays on the threads.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
