RV.Net Open Roads Forum: Travel Trailers: Bunk Ladder
Crazy_2
New Maryland New Brunswick
Posted: 05/06/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
We need to get a bunk ladder for our TT.
Found this one on line Click
However the smallest I can find is 60 inches, and I need one that is 50 inches.
I could buy the 60 inch ladder and modify, but I was wondering if anyone else has found/purchased one in the 50 inch range.
Any help/guidance would be appreciated.
Thanks in advance.
03 Nissan Xterra
Travel Star Sport XLT 24 FQB by Starcraft 3570 LBS Dry
Prodogy EBC, Reece Dual Cam WDH
Big_Johnson
Columbus, Nebraska
Posted: 05/06/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
My last trailer did not have a bunk ladder for the kids. I made one out of 2 pc. of 1" x 2-1/2" x 50+" of oak and some 1-1/4" oak dowels from the lumber store... I used a forstner bit and did not drill all the way through... I glued and screwed the ladder together and clear coated with poly... I used no stain... It looked better than factory... I then screwed it to the upper and lower bunks from the inside bunk lip back out... Worked great for the kids...
Regards,
Rob
Website: www.robjohnson.info
2008 Sprinter 311BHS
2004 2500HD 4x4 C/C 6.6L Duramax/5-Allison
Putnam 16,000 lb.,Equal-i-zer 12,000LB./1,200LB.
Champion 3500W RV Generator
Got Diesel!
Got Wood!
Got Dark Beer!
Got GPS!
Need Warm Weather!!!
Head'n Out
Wisconsin
Posted: 05/06/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Made my own out of oak and beech.....
Dave & Sue
Kiley & Emily
'03 Silverado 2500HD Ext Cab/Short Bed 4X4, 6.0L, 4.10
'05 KZ Frontier 2405PQS-F, Goin' KZ!
Equal-i-zer, Prodigy, Barker Hi-Power 3000, Putnam XDR
Rallies Attended: 9
arboscamper
South Dakota
Posted: 05/07/08 04:26am Link  |  Quote  |  Print  |  Notify Moderator
We also ended up making our own after a long search. We made ours out of 2x4's and 1 inch wooden dowels. Stained and clearcoated then used metal hooks at the top to hook onto the bunk. Works great for about $20!!
1993 Chevy K1500 4X4 5.7L V8 141.5 inch Wheelbase & 3.73 Gear Ratio
2004 Skyline Nomad North Trail Model #2480 UVW 4385, GVWR 6500.
dup4fun
NY
Posted: 05/07/08 06:04am Link  |  Quote  |  Print  |  Notify Moderator
I took the rubber feet off and hack saw the legs down to were I wanted them. I then put the rubber feet back on.
2008 Jay Flight 30 BHDS 07 Silverado 2500HD & 02 Trailblazer
Me 46 the Boss 43
DD 15 & DD 12
Brichon-Frize
Blue & Gold Macaw
Crazy_2
Posted: 05/07/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I think that is what I will do.
Thanks for the input.
Josie97
Minot AFB, ND
Posted: 05/07/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
I needed a bunk ladder as well and didn't like the current market offerings. I have 24" between bunks so the after market ladders would have blocked the aisle. I sold my last TT to a local cabinet maker. So I called him to see if he could do some mods to my new one. He made a counter extension and a bunk ladder. The ladder it measures 14" X 38". He screwed it to the top and bottom bunk so its very stable. It doesn't impede the closet door.
* This post was edited 05/07/08 04:09pm by Josie97 *
04 F-150 Super Crew FX4, 5.4L, 3.73
2006 Starwood SL 30CKS
Hensley Arrow
DW, DS, DD,
GSD
Aussie
sagexpman
Loveland, Colorado
Posted: 05/07/08 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I did the same thing works great
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
Campinfan
Washtenaw County, Michigan
Posted: 05/07/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a pipe cutter as in cutting copper pipe for plumbing, use that, it works great.
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
srd357
CT
Posted: 05/08/08 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I needed a bunk ladder for a Shasta trailer that we had. Got on the hiway to go to the lumber yard, and there was one on the side of the road. Must have fallen out of a moving truck. What a stroke of luck
Steve
