Diabs
Toronto, Ontario
Just finished up this mod. Tried to pull it off with as little damage as possible. Three screws that would be visible if the counter was removed. Zero screws for guests sleeping on the couch. Turned out better than I thought, sturdy and fairly cheap. Bought scrap Formica board from Home Depot for $.50!...brackets $12.00.
last
edited 05/06/08 08:16pm by Diabs *
View edit history
browns329
New Jersey
Nice Mod!
Did you cut the radius with a jig saw? Does it fold down or need to be removed? Looks like you used a wing nut for easy removal?
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
jmcnab
Toronto Ontario Canada
That looks nasty. Plus you're giving up a spot on the couch!
02 Yukon Denali XL
08 KZ Spree 324BHS
Diabs
Toronto, Ontario
Yes I used a jigsaw to cut that corner. Just need to loosen the two screws to remove the whole extension, fold it up and store it away.
Sorry about the size of the pic's...still trying to figure them out.
jmcnab
ps-It looks like if you sit on the couch without the extension you could get a bad scape/cut on your right leg from the wing-nut hanging out there.
jmcnab
sorry buddy... I just realized you're from Ontario. We have to stick together you know.
Diabs
Toronto, Ontario
jmcnab wrote: That looks nasty. Plus you're giving up a spot on the couch!
Thanks!...Just temporary till I'll come up with something better.
As for loosing a seat, just till after dinner!
Diabs
Toronto, Ontario
jmcnab wrote: ps-It looks like if you sit on the couch without the extension you could get a bad scape/cut on your right leg from the wing-nut hanging out there.
The wingnut is out of touch...unless you like to rub-up against the side of the counter!....all that counts is the DW is happy!
Diabs
Toronto, Ontario
jmcnab wrote: sorry buddy... I just realized you're from Ontario. We have to stick together you know.
You must be from the North? or right down town Toronto?
