Jerry B
Ozark Highlands
When I start my Generac it will not produce power until I shut it down and restart it. Not much of a problem but is this a precursor to a failure of some sort? I do exercise the genset under load about every three weeks.
Jerry B
1996 Dolphin 535,F-53.
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Generator Jim
Conway, SC
It sounds like the field flash circuit is not working or the brushes and slip rings are dirty and restricting the field flash current to the rotor.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
Jerry B
Ozark Highlands
Generator Jim wrote: It sounds like the field flash circuit is not working or the brushes and slip rings are dirty and restricting the field flash current to the rotor.
JimL
Could a low battery cause this problem?
Generator Jim
Conway, SC
If the unit cranks at or near normal speed, the battery is OK and probably not a factor in the "no initial voltage buildup" problem.
JimL
Jerry B
Ozark Highlands
JimL
Jim, is this a common problem and will it eventually lead to complete failure or unreliable service?
The genset leaks slightly and produces a very fine oil mist out of the cooling air outlet. Will this oil get into the revolving electrical components? Thanks.
edited 05/13/08 05:47pm by Jerry B *
Jerry B
Ozark Highlands
Update. I charged the weak house batteries and the genset now works properly.
