Head'n Out
Wisconsin
I put a brand new 12v deep cycle series 24 battery in the trailer last night, Monday. Now tonight it's totally dead! The only thing I can think of is the CO2 detector, but not in 24 hours! Any other suggestions on where to look?
Dave & Sue
Kiley & Emily
'03 Silverado 2500HD Ext Cab/Short Bed 4X4, 6.0L, 4.10
'05 KZ Frontier 2405PQS-F, Goin' KZ!
Equal-i-zer, Prodigy, Barker Hi-Power 3000, Putnam XDR
Rallies Attended: 9
4Kings
NE Missouri
Was it fully charged when you put in in
2003 Chevrolet 2500HD, CC, SB, 6L, 4.10, Auto, 4x4
2005 Wildcat 27BHWB, RBW 15K, Prodigy, TTT Mirrors
Head'n Out
Wisconsin
Yep, fully charged.
othertonka
Stockton, CA
It sounds like a dead short or something with a big draw is still on. Did the last cable "spark" when you attatched it to the battery? If so it is a indication of a short or a draw. You need to unhook the battery and Charge it fully. Then connect the neg, Ground, cable and then you need to get an Amp meter and temperarly put it between the Positive cable and the positive terminal of the battery and if there is a draw, the amp meter will show how
many amps is being drawn. The CO2 detector should not draw hardly any amps. If the amp meter shows a high draw, you need to pull 12v fuses one at a time while watching the amp meter until you find the circuit that is drawing your battery down. Good luck
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Rollincool
Always Rollin
I'll bet the brakes are doing it. Or the breakaway plug. That will kill a battery overnight faster than you can say Jack Robinson.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - Kā¢Hits 106.7
Diesel65
New York,NY
Check the refrig door heater switch, that runs on 12v.
1997 Chevy Tahoe 2dr Diesel
2001 Sunline 2363 w/ Reese HP and Dual Cam
JJBIRISH
Butler, PA, USA
are you sure you hooked it up in the right polarity...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
othertonka
Stockton, CA
Rollincool wrote: I'll bet the brakes are doing it. Or the breakaway plug. That will kill a battery overnight faster than you can say Jack Robinson.
I think you are on to something, Is the breakaway plug OUT?
ellenscub
Walton County, Georgia
Is the t.v. booster still on?
Earl E
Klamath Falls, Oregon
When that happened to me, it was the breakaway plug. It wasn't actually out of the socket but pulled out far enough that it no longer made contact. Otherwise, you have a short somewhere. But a short should blow a fuse.
2008 Keystone Springdale 252
2004 Chevy Silverado, 5.3 L V8
Prodigy brake control and Equal-i-zer
Retired and traveling all we can!
