bezoar
WI
We're shopping, just on the internet so far,
I can't find anything about this on their website.
My truck manual says anything over 2000# needs brakes...
lottknox1
north carolina
yes
2005 Flagstaff 831BHSS
2006 Ford Expy
Prodigy
Hensley Arrow
McKesh Mirrors
havedreamwilltravel
You'd be hard pressed to find a travel trailer that does not come with brakes. Yes, the Jayfeathers have brakes. You will need to buy a brake controller and have it put in on your tow vehicle. When you hook the cord into the 7 pin controller you will be hooking the brakes up to your tow vehicle so to speak. The brake controller brakes the trailer with the truck (in very simplistic terms)
Recommend the Prodigy.
2007 GMC Yukon Denali - 6.2L 380hp/417ft-lbs,0-60 in 6.2 seconds
2007 Jayco Jayflight 27BH
Equalizer Hitch, Prodigy Brake Control
Our Truck and Trailer
Easy Trailer Mods-NEW pics added 4/10/08
Visited a lot of states, haven't camped in many...yet.
hikerh7
salem, or, usa
Yes the Jay Feather has brakes. Some of the smaller models (Sport and Ex-Port) can be ordered with surge brakes in place of the electric brakes. I saw a Jay Feather Sport with factory surge brakes.
05 Jayco JayFeather Sport 186, 00 GMC Sierra
subourbon
Huntsville, AL
Yes, Jayco Feather Trailers have brakes.
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
mrasoul
Austin, Texas
What is the difference between surge brake and electric brake?
2007 Jayco 26JTX and 2005 Dodge RAM 1500, 4.7 V8 Magnum (Reg. Cab).
Happy RVing!!!
Dixonmatco
Santa Rosa, California
A surge brake consists of a master cylinder mounted on the trailer tongue which is acutated when the tow vehicle hits the brakes and the trailer starts to push on the tow vehicle hitch. This operates the trailer brakes using a hydrolic brake system. There are no connections to the tow vehicle relating to the operation of the brakes (except the brake lights) and there is no brake control necessary in the tow vehicle.
Electric brakes are operated by a brake control in the tow vehicle that is connected to the vehicle brake light circuit, and the good ones also have an inertia sensor which controls the rate of application by sending voltage through the trailer wiring connector to a set of brake drums and shoes that are applied when current is present.
In the past electric brake controls tied into the hydrolic braking system of the tow vehicle to acuate the control, sending more current as the TV brakes are applied more but that is not so commen these days.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
