maagk
Greensburg, PA
We are unwinterizing our travel trailer and we are getting hot water out of both the hot and cold faucet. What did we do wrong? This is out of all of the faucets, bath tub, sink and kitchen sink.
Thank you in advance.
bldrbuck
Boulder, Colorado
I would suspect that the valves for you hotwater bypass are not in the correct position.
Camping Dutchman
NJ
Check your bypass valves on the hot water heater, you didn't close the crossover valve
2008 Chevy 3500 cc DRW Duramax
2009 Cedar Creek Silverback
2004 United Specialties Sold, bye baby I will miss you!!!
Member:Good Sam Club Haulin Highlanders
Cheddarhead
Northern Wisconsin
try Shutting the middle crossover valve by you water heater bypass.
2006 Chevy 2500HD EC/SB 4x4 Duramax/Allison
05 Jayco "Jayflight" 285RLS
Some of our trip Pics
hershey
Albuquerque,(fulltime) NM, USA
Or the shower either inside or outside is on but the shower head is turned off.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
2milesup
Leadville, CO
Check to see if you're in Arizona and it's August?
Jerry, Lori and Parker the Chocolate Lab
2005 4Runner 4.0 4X4
2007 Dutchmen Lite 18B
Reese Pro Series SC, Prodigy, Honda EU2000i
emaav
Hillsboro, Oregon
When our hot water heater is on I will get about 5-10 seconds of hot water through the cold, then it will flow cold.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
Golden_HVAC
Fulltime, CA, USA
emaav wrote: When our hot water heater is on I will get about 5-10 seconds of hot water through the cold, then it will flow cold.
Your water heater is supposed to have a check valve at the inlet to the hot water tank to prevent water from leaving the tank when it expands (due to heating the water). This check valve will cause the hot water to be a slightly higher pressure when it heats up cold water to 130F. But after the first heating, when it goes from 100 - 130, the pressure barely changes.
The check valve causes the water pressure in the cold water line to be a slightly lower water pressure, that is why the shower only has cold water going into it when the hand valve is shut off for a few seconds.
If you are getting hot water into both the hot and cold water lines, then perhaps the winterizing bypass valves are in the wrong position. Try running some more hot water, then run the cold water for about 10 seconds to see that you have cleared out the warm water from the cold water lines.
If the problem continues, write back. If it is solved, please post what it took to fix the problem, so others that search for this post will know how to fix their RV too.
Thanks,
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
tvman44
Southwest Louisiana
Bypass valve??
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
hershey
tvman44 wrote: Bypass valve??
Most later model water heaters have a winterizing valve system that allows you to bypass the water heater, drain it and you don't have to fill it full of the pink stuff. It can be a somewhat complicate valve system or something very easy. You just have to study the valving setup to figure it out.
