RV.Net Open Roads Forum: Tech Issues: Norcold 1200 is being extended
 > Norcold 1200 is being extended
firedoc
Meridian, Idaho
Posted: 09/21/10 06:36pm Link  |  Print  |  Notify Moderator
How much does that Kenmore weigh. If its more than the Norcold (and I assume that it is) would that make a difference being in a slide?
'06' 38L Fleetwood Bounder
6 speed Allison
300 Cat
2012 GMC Terrain
Roadmaster baseplate
Ready Brute Tow Bar
And M&G brake system
was_butnotnow
Fulltime: Emery, SD
Posted: 11/01/10 09:40pm Link  |  Print  |  Notify Moderator
I called Norcold and they said my unit was a part of the recall. Now wanting to know if the problem is only when the unit is used on AC. I am dry camping in AZ for the winter with my 1210 unit set on propane.
Sharing Travel Journals and Adventures Hitchitch.com
homeon6wheels
Landrum, SC
Posted: 11/13/10 06:54pm Link  |  Print  |  Notify Moderator
Just received a recall letter from Norcold dated 11/8/2010 extending a recall to the entire 1200 series out through 1212, This time it involves installing a "high temperature sensor".Sound familiar?
My unit is included in the recall even though it was installed in February 2009, replacing a 6 year old unit, original to the M/H, That unit failed 3 months prior to a recall being issued for it, also for a heat sensor. To their credit, Norcold participated in the expenses of replacement.
My question is: Has it occurred to Norcold to address the problem of leakage and overheating, rather than throwing "band aid" measures at the symptoms?
The inconvenience is outstripping the otherwise fine performance of the reefer, which is a model 1210IM
gmachine
Marion,IN & Chuluota,FL, USA
Posted: 11/15/10 07:29pm Link  |  Print  |  Notify Moderator
Our 19 cu.ft Kenmore(replacement for a 1200)weighed LESS, and went in w/o much modification. Not as pretty but works better and saves $30.00/mo. in electricity.
Runs on MSW inverter just fine and in approx. 4,000 mi we have had perfect performance. We are quite pleased but would like to sell the 1200 to get it out of my workshed in FL.
Bering MD23(Cummins ISB)w/60" flattop Kenworth sleeper & 2005 Excel 35MKO Limited, 2006 Scion XA.
was_butnotnow
Fulltime: Emery, SD
Posted: 11/19/10 06:44pm Link  |  Print  |  Notify Moderator
I had the recall done on my Norcold 1210 today and the dealer told me to send my paperwork to Norcold and they would send me $50. They paid the dealer directly $45 for the recall so why would they also send me money? He said it was true.
Is It?
