I installed the Koni FSDs. I run 100 in the front tires and 95 in the back duals. I have never weighed my RV. I seem to get outside rib wear if I run any less air in the fronts. The rib wear seems to be even on the inside and outside of the tires. I know I am in the minority about the shocks.
Lee and Joan Haeberlein
Arcadia, CA
08 Dolphin DL35C on WH W-24
07 Honda CRV
Brake Buddy
Really should weigh all 4 corners. How about a front end alignment?
1994 Pace Arrow 33L Class A 454 P30 2002 F250 lariet crewcab 4x4 7.3 PSD srw short bed auto 3.73 gears,reese 16k slide hitch,reese brake controller ford factory aic,autometer three guage pod trany temp,pyrometer,turbo boost,banks 4inch monster exhaust,aFe air box,sonnax valve and tri springs,magnafine trans filter,Wicked Wheel,TS flip chip 75/100/125/OMG,03 tt heated/signal mirrors,runningboard leds.Other than that its all stock
2oo4 ground up ridgid chopper 120rwhp http://community.webshots.com/user/oneHD
Thanks for the reply Mike. I did get an alignment when it was new and I had it loaded but not since. I do not get abnormal tire wear. I just get outside edge wear like low inflation. That is why I kept the front tires inflated to 100psi.
lhaeb wrote: Thanks for the reply Mike. I did get an alignment when it was new and I had it loaded but not since. I do not get abnormal tire wear. I just get outside edge wear like low inflation. That is why I kept the front tires inflated to 100psi.
Something doesn't add up here. Your unit should have had Michelin 235/80-R22.5G tires and an 8000 lb front axle. For 8000 lbs, you should only need 85 psi (maybe 90 if you want a little margin).
Either your alignment is screwed up or you're overloading your front axle (and maybe rear, also). Weigh the 4 corners. If 8000 lbs or less on the front axle, drop the air pressure and get an alignment done. If over 8000 lbs, well............. !!
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
Yes, I got the KONI FSD's. I just contacted LTB Motorsports where I purchased them (by phone). They stated that the rear shocks for the F-53 V-10 chassis comes with a bare rod. (part #FORD F53 TRITON V10 99+ REAR FSD 8805-1019). Seems odd to me. But I see few products with such a good recommendation.
Based on this thread that I just read yesterday, I bit the bullet and ordered a set of Koni FSD's today. I did a Google search for the best price on the web, and it directed me back to another RV.net thread, where someone suggested a site called Shox.com. I sent Shox.com an email request for a quote, and was quoted a price of $569 for all four shocks, which was about $100 less than buying them directly from Koni.
The quote said to call their toll free number to order, which I did today. The gentleman that I spoke to, said the price that I was quoted was $100 less than their list price, but he gave me that price since I was emailed a quote number. Sometimes it pays to shop around.
Craig
2005 Providence 39J
2007 Tacoma PreRunner Double Cab Dingy
2002 EZ-Go Custom Electric Golf Cart
Thousand Trails & Coast to Coast Members
CJ7 and Craig P you are both right. My koni's are bare rod on the rears and shox are the cheapest to buy from, which I did. OOOOHHHH WHAT A DIFFERENCE in the ride. They are worth the money IMHO. Enjoy the ride. We Are!
2001 suncrusier, 32-v, Ford V10, 4 Koni FSD, dinning slide, No leaks, 1 wife, 1 westie, life is good! 03 malibu toad sometimes, roadmaster brake pro,roadmaster Blackhawk all terrain tow bar!
Ok...I replaced my factory Sach's shocks with Koni FSD's today. I hate to be the fly in the ointment, but I just don't feel any difference driving around town. I hit the same bumps and railroad tracks coming home as I did going to the shop, and I can't say they improved my ride at all.
I sure hope I feel a difference on the freeway during our next trip. If not, you can bet I'll hear it from the DW when she see's our next credit card statement!
Craig
Take em back and get your money back....
Ron
N6QL
2002 36' Country Coach Allure 350HP Cummins
2001 Jeep Wrangler Sahara
1978 Cessna T210M My Flying My website
Craig
Have you weighed the 4 corners and matched the tire pressure to the weights? Ten more psi than needed will affect the ride.
