RV.Net Open Roads Forum: Travel Trailers: Extended Counter Part II
 > Extended Counter Part II
Diabs
Toronto, Ontario
Posted: 05/07/08 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Well, I wasn't really happy with yesterdays start. But then it came to me last night!
This first pic is what I was working around...wanted to mount a piano hinge underneath..but no luck, as you can see the Formica hangs down past half-inch wood.
I lost 2.5inchs in order for it to close proper.
Looking at the pic below....I think I may be rounding out the pointy corner!
LAdams
Northern Illinois
Posted: 05/07/08 09:52am Link  |  Quote  |  Print  |  Notify Moderator
That's exactly what I did with mine - used shims under the bottom of the shelf as my hinges mounted to the cabinet side... Can't see a lot of detail but heres a picture of mine... My dealer procured some counter top material and trim for me as well as the hinges so it matches the existing counter tops...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
bigalx58
Onta Rio
Posted: 05/07/08 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Your extension looks intriguing. What are the names of the hinges/support that you're using and where did you get them? Thanks.
Diabs
Toronto, Ontario
Posted: 05/08/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
LAdams, yours looks like it came with the trailer! Nice touch getting the same counter material.
