RV.Net Open Roads Forum: Tech Issues: Gray water tank repair
 > Gray water tank repair
vetteopel
pittsburgh PA
Posted: 05/07/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I have a crack in the Gray water tank at the top of the tank. It only leaks when it's full or facing down hill, But it leaks a lot. Has any one repaired there tank? The tanks not poly but ABS plastic. I've pulled the tank off so I can do a proper repair. I would replace it with a new one but I'm having a hard time finding one to fit in the space I have.
Dave
davidj54
South Alabama
Posted: 05/07/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Your best bet is to replace it but if you're absolutely sure it's ABS (most are polyproplylene) you can glue it. Buy the glue that's specifically for ABS. Check at your local big box store and find ABS in sheets and buy a piece big enough to cover the area. If it's a split, drill a small hole at each end and glue the piece of sheeting to the tank. You can also weld it but most people aren't equiped to do so. As a last resort, you could try J-B Weld on it.
If you're interested in replacing it check this place. www.plastic-mart.com
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
mooreadventures
North Carolina
Posted: 05/07/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
mfox20
Fort Worth, TX
Posted: 05/07/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I recently repaired a 1/2 inch crack on a gray water tank with EternaBond tape and it held. It would allow the tank and crack to move as it was filled without leaking. I could never get a glue joint that would not seperate when the tank expanded as water was added.
nbounder
Arizona mountains
Mark - could you repeat that?
dobbler98
Ohio
Posted: 05/07/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yep I second the eternabond tape repair.
Eternabond
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
jmanatee
Willington, CT
Posted: 05/07/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I third the Eternabond.
Jon
Our RVing Web Site | Our Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
1992 32' Georgie Boy Swinger
Hayes
Grand Prairie, TX
Posted: 05/07/08 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have repaired 3 holding tanks with Eternabond and all 3 held up with no problems. Best way to repair.
Hayes
Jerry, Alma & Jasper the lovable Corgi
International 4700 Custom Tow Truck (Pepaw's Pull Toy)
38' King of the Road Marquis fifth wheel.
"Running the roads seeing God's Great Creation!"
vetteopel
pittsburgh PA
Posted: 05/07/08 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like I'll run down to the local RV store for some Eternabond.
Dave
bill h
el segundo
Posted: 05/08/08 12:34am Link  |  Quote  |  Print  |  Notify Moderator
I have repaired ABS things by mixing a putty of ABS cement with ABS filings and forcing it into the crack and then building up putty over the repair. Rough it up first.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
