batchee
maine
I am having a problem solving a leak around my bedroom outlet. When it rains heavy water will come in there. I have sealed the seam on top and also around the light. Still leaks.
trnfla
Tampa
I took a water hose so I could control where the water was on the trailer. Then I had my DW watch with a flashlight while I ran the water from the hose accross the side until she saw water coming in. This helped me isolate the leak.
Have a great time camping,
Terry
Please say a Prayer for my 9 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
USAFBILL
Alabama
Find a dealer that can perform a Leak Detection before it is to late. Runs around $100.00 if out of warranty. Worked for my Cougar.Leak Detection
trnfla
Tampa
Here is pics of a homemade leak tester done by Gaffer22 Leak Tester
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Wayne Dohnal
Banks, OR.
Having had this same problem several times with my former Cougar I'm fairly confident saying that the entry point for the leak is in one of the front corners where the rubber membrane meets the front cap. There's a metal strip that runs the width of the trailer, and it's caulked to the rubber membrane. There's most likely a small crack in the caulking in one or both of the corners. Making it worse, this is a low spot that the water puddles in.
Rain water running out of the bedroom outlets is unfortunately a standard Cougar 5th wheel feature. My best guess is that there is flexing of the front cap as you bounce down the road, and when you transfer weight between the pin and the landing gear. On mine, the ends of the metal trim strip weren't securely fastened down which contributed to the problem. I finally looked at recaulking the corners every year or two as a standard maintenance item. If you haven't done any roof caulking before, make sure you use the right stuff for EDPM roofing. Removing the old caulk is easier if you do it on a hot sunny day (wearing sunglasses!), or use a hair dryer.
2009 Fleetwood Icon 24A
EU2000i generator
batchee
maine
Thanks for all your help.
erobinson1
Bainbridge,Ga.
Ditto Wayne Dohnal's post. I had the exact same leak as yours on my Cougar. Chased it for months! While at the beach it cam e arain and I was determined to find and fix the leak. After the rain stopped, I eternabonded the entire seam on front where the rubber meets the ABS cap and was sure I had fixed it. Next rain it still leaked. I recaulked the metal strip running vertically as well as the corners and bingo! It is fixed.
batchee
maine
YEh Thanks.. I too caulked the entire seam to no avail. Still leaked.
Today I did as you and Wayne said and hopefully that will work when I get the next rain.Guess it is a Cougar trait I'm finding out...
Neilm_108
Calgary, AB
Well I guess I'm now joining this not-so-exclusive club. My brand-new Cougar 243RKS is leaking - Carpet is wet beside the bed, adjacent to the front door, but the water is not coming in through the door opening itself.
Have a call into the dealer, who is 450 miles away....
