RV.Net Open Roads Forum: New Info From Josh about Equal-i-zer Hitch Bolts (long)
Search only in Towing
Open Roads Forum  >  Towing
 > New Info From Josh about Equal-i-zer Hitch Bolts (long)
KC8WX
OH IO
Posted: 05/10/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
VintageRacer wrote:
the best torque wrenches typically available, without going to really over-the-top stuff, are from here: http://www.torqwrench.com/
They make them for Snap-on, for example. My main wrench is a Snap-on Beam type click wrench, made by them. I also have one of these: http://www.srtorque.com/tabeam.html
that I got when an aircraft maintenance company was being liquidated. Harder to use, simpler, but more accurate and more expensive than the snap-on, when new.
I have other wrenches for engine assembly, that sort of thing. FWIW, a wrench that is accurate in the 400 - 600 lb range will cost in the $1000 and up range and will be about 6 feet long, 3/4" or 1" drive.
Brian
An Equipment Maintenance friend found these Torque Wrenches for me.
Pittsburg 100-600#'s 42" Torque Wrench
Adapter Set
Here's a more expensive brand same torque settings:
Northern Tool 100-600# Torque Wrench
I also got two Grade 8 Bolts 3/4" x 5" with Lock Washers and Nuts today at the local TSC. Now I have to get a Deep 1 1/8" Socket for my 1/2" Drive. Can't reach the nut with the longer bolts.
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
