RV.Net Open Roads Forum: General RVing Issues: Where to Carry Genny Gas
 > Where to Carry Genny Gas
HighCover
Fort Worth
Posted: 05/07/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a 23' Rockwood and a Tahoe, with a Yammy EF2400i. The genny goes in the trailer until we set-up camp. Where would you carry a 1 or 2 gallon Blitz gas can? I'm leaning toward the outside storage compartment of the trailer.
Thanks...
2007 Tahoe, 5.3L
Rockwood 2306
portablevcb
Tijeras, NM
Posted: 05/07/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Back of truck or on a rack on the back of the trailer. Not in a compartment in the trailer unless it is well ventilated (and I probably would not do it then either). Would not put the genset inside the trailer either. The gas is vented to outside and any heating of the interior means fumes will get in trailer.
charlie
2006 Toyota Tundra Crew Cab
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
rv2go
Somewhere between Knoxville, TN and the coast.
Posted: 05/07/08 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I carry my gas in the gas tank of the Jeep. When gas is need, I siphon out a gallon at a time. Now, I do get strange looks when doing this.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee
www.rv2go.us
I'm here #4335
Picasa Photos
PopBeavers
San Jose, CA
Posted: 05/07/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I used to have a 1981 Datsun pickup truck. I would disconnect the rubber fuel line at the filter, point it towards a can and turn on the electric fuel pump.
These days that might not be agood idea. I have heard that the pressure is a lot higher with enjectors that back in the days of carbs.
For a small quantity I just use the gas bottles that I use when I go backpacking. They are air tight. Something like this
Wayne in San Jose
2002 Chevy Silverado 1500HD 4x4 Crew Cab
2005 Trailmanor 2720
Valley Odyssey brake controller, Honda 2000 generator, McKesh mirrors
Yamaha WR250R, Polaris Sportsman 700 X2, Polaris Scrambler 500
1997 Dodge Dakota stick to tow the ATV trailer
topflite51
In The Desert of Nevada
Posted: 05/07/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
On rear bumper of trailer or on tongue of trailer.
David
Just rolling along enjoying life
magster
Palm Bay, Florida
Posted: 05/07/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Our gas, in 5-gallon plastic cans, rides in the bed of the PU by the tailgate, secured with a rope and bungee chords to keep them from sliding around: 5 gal, regular for the genney, which we sometimes run while under tow to keep the trailer cool, and 5 gals of diesel in case we miscalculate and find ourselves a long way between stations in remote areas. (It ain't happened yet that we needed it, but it's about piece of mind)!
Cheers
Magster
2 retirees
2 dogs, 1 cat and a foul-mouthed parrot
2003 29RL Dutchmen Classic, "The Ark"
2001 Dodge 2500 diesel
Peg Leg
Anderson, IN
Posted: 05/07/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
He's got a a Tahoe not a truck.
I siphon mine from the tank. I use a 3/8' dia clear plastic hose about 6' long. Nice loop to the ground out of the tank and you can see the gas coming.
Keep the end of the hose above the filler and the gas stops at the same level as in the tank. Stick it in the can and lower it to the ground. When your done or want to fill another can, just lift the full one above the filler neck and slowly remove the hose. You should see the gas drop back the the tank level. Stick the hose in a empty can and lower it again or if your finished lift the hose to let gas drain back into the tank and then remove the hose.
I've been doing this for years and not one drop if gas has made it to my mouth. my clear plastic has yellowed over time but you can still see the gas inside.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
HighCover
Fort Worth
Posted: 05/07/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, ya'll got me thinking now. I can drain the genny so it's empty while we drive. Looking at putting a 5-gallon metal Blitz can on the rear bumper of the trailer, which would give me plenty of juice for the genny, and the "peace of mind" factor for the tow vehicle. However, the 3/8" hose from he gas tank is pretty darn good too :-)
pnichols
Santa Cruz Mountains
Posted: 05/07/08 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a special safety certified gas can to carry two gallons of fuel for my small Honda genny and carry the can in the only outside compartment in my Class C that meets these conditions:
- the compartment is all steel lined
- the compartment is not open at all to the interior
- the compartment is not near the furnace outside vent
- the compartment is not near the water heater outside vent
The safety certified gas can was not inexpensive .. about $70 for the two gallon size, but I figured that safety has no price.
I carry the Honda in the only outside compartment large enough for it, but this compartment is not steel lined. I figure/hope/assume that Honda has designed into it a very safe steel gas tank and also, I've never smelled gas around the Honda after filling it's tank or when running it.
Phil, 2005 E450 Itasca 324V Spirit
Mousefart
New Jersey
Posted: 05/08/08 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Rear bumper of my trailer.
Frankly, I'm amazed it hasn't been stolen yet. Two gallons of gas is worth the risk of going to jail for a lot of people these days.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
