RV.Net Open Roads Forum: Water Pump Issue that won't go away.... help
 > Water Pump Issue that won't go away.... help
RandiOwen
Tomah, WI. 54660
Posted: 05/16/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Ok just my 2 cents, i had this close to no pressure also, you have replaced the pump but did you change or clean the screen that infront of it between the tank and pump, ours look ok from the outside but when i took it apart it was pluged up with grit and sand!!!
Randi Owen (N9UOM)
Tomah, WI.
MIB (Men In Blue)
WI Good Sam Webmaster
2004 35R Fleetwood Bounder M/H
2005 Suzuki Grand Vitara Toad
mchero
Concord, NH
Posted: 05/16/08 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with most of the others. I think you must have a cracked line or something. That pump is sucking air!
Robert McHenry
Concord, NH.
1993 Fleetwood 36' Pace Arrow
Cummins 8.3l Turbo 300hp (uprated)
Allison 3060 Trans
http://dieselrvowners.com
clydedoerr
Hardeeville SC
Posted: 05/16/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
With mine, the hose running from the tank to the pump had a kink in it. Test by running hose from bucket to pump and see how it does. If thats it, you may have to replace the hose.
Dave H M
IL
Posted: 05/16/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
92
If I ever go into a dealer with something like that, I get the service "expert" in tow and demonstrate the problem. That usually gets the deer in the headlight look but then they have to do something besides turn a service order to the comapany for warranty work.
good luck
Hurricaner
Hurricane Utah
Posted: 05/16/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
One other possibility is there is a strainer on the fitting on the tank that is plugged. Mine has one even though it looks like a standard fitting, pull yours and check it.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
ryoung
Indiana
Posted: 05/16/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
92DakotaHD wrote:
I put 6 gallons in. (50 gallon tank) and the pump sputters, 3 more gallons, the same. 6 more the same sputtering. I finally just run the hose for 10 minutes and it works like a charm with a lot of water.
Assuming that the initial 6 gallons of water you put in was sufficient to cover the pump inlet on the tank and prevent the pump from pulling air along with water, I would say that your problem is that the pump is mounted to high above the tank. The pump is not strong enough to lift the water from a near empty tank or the suction pressure is great enough to partially collaspe the hose and the pump is probably cavitating. As you put more water in the tank, the lift is decreased and the pump performs better.
I have the same problem with mine. Mine begins to do the same as yours when the tank gets down near 1/3. This is not a critical issue with me since I am usually hooked to city water supply. But relocating the pump is on my todo list.
ryoung
2004 Dodge 3500 Dually HO 6 sp 4.10, Jordan Controller
2005 SunnyBrook 31BWKS
2004 Lance Lite 915
Hurricaner
Hurricane Utah
Posted: 05/16/08 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
My pump is 2 feet above my tank and the tank is only 6 inches high. So it will work if you get the suction problem worked out.
Sam
