My 42" HDTV, Bose Sound System, etc, functions the same when running on a MSW UPS unit, or from the wall. Just as clean & crisp, no noise. Most things will run will operate fine on a MSW inverter. $29 will get you a 400 Watt Vector inverter. Try it, you'll probably like it.
I used to have a 2005 Diesel Bounder with a MSW inverter. We found that when using our DirecTV on the upper channels (300+) we would get intermittent reception. Switching to a pure sine wave inverter for all the electronics solved all the problems.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Clay L wrote: Harbor Freight has a 400 watt true sine inverter on sale for about $30. That's pretty cheap for a true sine inverter and I don't know how good it is.
If you're talking about this one (it's the only 400-watt inverter I saw on Harbor Freight's website and it sells for $29.99), it is a modified sinewave inverter, not a true sinewave inverter.
You are correct.
I haven't seen the unit just the ad in the flyer my SIL got yesterday.
I just went over and got the the flyer from her and found the ad. It is the one you referenced and is a modified sine wave.
In the ad the word "modified is by itself and on the line above the rest of the wording and is next to a picture of the unit. The word "sinewave" is the first word on the next line and faked me out.
I thought that was too cheap for a true sine inverter.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
You are correct.
Looking at the web page shot, I wonder what the real continuous rating is since all it says is "400W for 30 minutes" and "800W Peak". Probably only 300W or 350W at best but for $29.99 what do you expect.
We have an older AC/DC TV/DVD combo with a NTSC tuner. We don't have a PSW inverter. I did find a converter box that uses a small plug-in "transformer" that changes the 120 VAC to 12 VDC. This would be ideal for boondocking; no inverter would be needed. The converter box is the Artec T3A-Pro. (We don't have one yet, but it's on our list!)
