RV.Net Open Roads Forum: Fifth-Wheels: Suspension air bags
Newest  |  Active  |  Popular  |  RVing FAQ  |  Blog Forum Rules  |  Forum Help and Support  |  Contact
 > Suspension air bags
coachman05
Minnesota
Posted: 05/08/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
So is there a switch to install in the cab of the truck to adjust the Firestone bags? Or how do you adjust them?
rick_niagara
Niagara Falls, Ontario, Canada
Posted: 05/08/08 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
here's a link to Firestone site, describes interior switch
2008 Fleetwood Prowler 235RLS
2005 Dodge Ram 2500 4x2 5.9L Diesel 3.73Limited slip 6speed manual
Pullin' 5ers since 1988....Have a nice day
JustLabs
Washington State
Posted: 05/08/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the onboard air,you can adjust them from the front seat.
I didn't want to mess with plumbing in the onboard air,so I just installed the Firestones with the standard fill valves. The valves are under the bed near the frame for now. I'm going to relocate them to the fuel filler door soon.
My Pacbrake has a quick disconnect on the compressor that allows me to connect an air line and a bunch of different air fittings. I use the Pacbrake when I need to add air to the bags.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
JustLabs
Washington State
Posted: 05/08/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
DelawareCamper wrote:
I'm also looking to order the Firestone Ride Rites,,, looking at Summit racing , about $260 shipped,,, anywhere else to check?
I bought mine from Summit. They were the cheapest by about $20-25 I found.
countryrose
Redding, Ca
I have the Firestone Ride Rite and they are great. I have the on-board compressor, gauge and switch and can adjust/add or reduce air from the drivers seat. Got a quote from Camping World and then went to my local Chevy dealer showed him the quote and he matched the CW quote. If you go this route it will cost in the neighborhood 0f $900 to 1,000. I also run about 10 to 15# in mine at all times, with 5er loaded my gauge in the cab raises to about 30# with the added weight. You should never run with no air. I know it may sound pricey but in my mind it was well worth the investment.
glsurrat
Virginia
Posted: 05/08/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Summit had the best prices when I bought my Firestone Ride-Rites.
Scot mentioned the mounting brackets for the Airlift is outside the frame while the Firestones mount between the frame and the spring pack. I've heard guys worry about shearing the mounting bolts on the Airlifts, but I've never heard of it actually happening.
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
tartan camper
Canandaigua, New York
Posted: 05/08/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
We just had the Ride Rite bags installed - a bit pricey I thought, but well worth it. What a difference in ride and handling! Absolutely would do it again.
Backpack to fiver...and everything in between. What a life!
DelawareCamper
Newark, Delaware
Posted: 05/08/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Ordered the Ride Rites today from Summit, $251 including shipping.. should be here in 2 days, and have a trip with the 5'er next friday.
Any tips to the installing?
Kejsj30
Portland, Oregon
Posted: 05/08/08 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I did the job by myself, would have been much easier with someone to help. If I were to do it again I would take the rear wheels off for a little extra room to work with.
Like most, routed two lines (one for each bag) and stuck each valve through the mounting bolts for the rear liscense plate. Give a good clean look and if you ever want to remove the airbags just bolt the plate up and you won't have any additional holes drilled anywhere on your rig.
2008 Chevy Silverado 2500HD
2008 Keystone Raptor 3712TS
2000 Bayliner 2855 Sierra SunBridge Boat (SOLD)
2007 Raptor 700R
2007 YZF 450RSE
2008 Raptor 700RSE
hwrd_shnnn
kentucky
Posted: 05/08/08 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Firestone bags. Absolutely great
