TomW2
Southwest Washington State USA
skipnchar wrote: ... we and our traveling companion who ALSO stayed hitched could NEITHER of us use our vehicles to drive to the shelter. ... we ended up jogging through the woods to the shelter ... You jogged down instead of unlatching the hitch and raising the tongue off the ball?
LarryJM
NoVa
incoo wrote: On day to day travel staying only a night is there any harm in leaving the trailer hitched up.There is probably a way(put front post down ect..).Just wanted to verify any techniques you guys might share.First time with a 30 ft coachman, picking it up next weekend.Had an Aliner but this is a different ballgame. Thanks
As long as you're not way off level front to back we do it all the time. To prevent the bouncing some I put my screw levelers in the back and then use the electric tongue jack to put some weight on the rear and just accept some of the slight bouncing.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
LarryJM
NoVa
jeffnkelly wrote: We have done this in the past. We stopped a few times and did just that when we had our TT. Just unhooked the sway and WD things and put the front foot down. Next A.m... Just the opposite and we were on our way. DW and I had the camper hitching down to a science. Less than 10 minutes from backing up to the hitch and on our way.
Just be sure to disconnect any WD and anti-sway equiptment...
I have never when staying hitched disconnected any of the WD/Sway with my current Equal-i-zer or with my older round bar with friction sway. I did loosen the friction sway while DW was registering at the office so it was not so tight when backing and jocking around getting into the site if it was a back in.
Larry
NavyDood
DFW
Leave it hitched. There is no way to cause any kind of undo stresses on the truck. Drivng down the road is 1000000% stressful than sitting static. If you are concerned about movement, then lower the rear jacks for some stability.
- 2004 2500 QC Short Bed, 4x4, 48re, Brite White, HOG 4" T-304 T-Back, Self made PSMBuick style intake, Isspro Pyro/Boost/Tranny Temp sittin on the dash
- 06 Pilgrim Legends 30RE2SLF-5 12,000lbs loaded
- B&W Hide-A-Ball w/5th wheel Companion
lovemountains
North Carolina
We've learned that when we stay hitched up for a night or two, we need to disconnect the electrical connection to the truck. It can drain the battery of the Tow vehicle.
Chuck&Gail
In the Colorado Mountains
We do that all the time. We do use the electric tongue jack to take a bit of the load off the TV suspension.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
N9MB
Indiana
We always leave the fiver hooked up for overnighters. As previously stated, try to level as best as possible, set the park brake lower the front landing gear and rear stabs and chock the wheels.
F350 PSD CC DRW Tow Boss
Heartland Bighorn 3600RE
Airsafe Revolution
La_Bolt_Fan
Los Angeles, CA
Why is this??? Theft?
Backpacking one week, RV'ing the next!
martipr
Haltom City, Texas
Stay hitched, level with tongue jack and ignore the movement. Pretend you are on a boat. This is supposed to be fun, not work.
2007 29' 27FBV Trail Bay V Series
2007 Dodge Ram 1500 Mega Cab 5.7 V8
Reese Strait-Line Dual Cam Hitch
