RV.Net Open Roads Forum: Tech Issues: Replacment axle for utility trailer
 > Replacment axle for utility trailer
OlderThanSand
Tollhouse, Ca
Posted: 05/10/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I don't know what's available on the east coast, but here we have Century Wheel & Rim and a company called Redneck Trailer. You can order anything you want. Both are chains but I don't know where all the stores are. Look in your yellow pages and you'll probably find something. It may cost less for a new one than to have a shop straighten your old one.
2002 4x4 Super Duty PSD
2006 22' Carson Titan
2006 Polaris Ranger
2007 Suzuki LTZ 400
2007 Honda TRX 250EX
1995 model dune crazed granddaughter
shortlid
Derry, NH
Posted: 05/10/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Just looked up the companies you stated and none in my area. I think I might just flip the axle to help flaten it out for me when I load it down.
shortlid
Derry, NH
Posted: 05/10/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Cox89XJ wrote:
When I was a kid, I helped my dad straighten a utility trailer axle. We used a bottle jack and chain.
How did you do this?
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/12/08 12:19am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like the axle is bent horizontally rather than vertically.
Your 90-degree rotation idea should work, but what about the spring pads? They will need to be re-welded onto the adjacent side of the axle tube.
Cox described 'pulling' the axle tube back into alignment using hydraulic power. This can also be done with a chain or cable hoist. Secure ends of axle so they can't move, hook onto something stationary and solid on the opposite side of the bend, hook onto the center of the axle, and pull it back straight. Watch that you don't bend up anything else in the process. It would be better to remove the axle from the trailer and put it in a press to do the bending.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
rob85546
Hot arizona
Posted: 05/12/08 03:13am Link  |  Quote  |  Print  |  Notify Moderator
good place, When I needed one, I just went to a local place that deals in trailers and they got me one for a reasonable price...
1995brave wrote:
Did you check out Northern Tools?
Trailer parts
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
shortlid
Derry, NH
Posted: 05/12/08 05:14am Link  |  Quote  |  Print  |  Notify Moderator
It is a square axle and does not have spring pads. Soo it should be very easy.
shortlid
Derry, NH
Posted: 05/14/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
The only thing that I did notice is the top of my square axle there is a divit to acept and bolt that helps keeps the second spring in place on the leaf springs. Can I just take this bolt out when turning the axle over 45 degrees and let the bands hold the springs together. Looks like it is more for axle centering than keeping the spring together?
1995brave
San Antonio, TX
Posted: 05/14/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do not remove the bolt. The bolt is used to keep the springs together(keeps them from sliding forward and backwards also). The bands are to keep the springs from banging up and down on each other.
shortlid
Derry, NH
Posted: 05/17/08 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Well I have to to rotate the axle 45 degrees. The springs stayed together with just the bands on them. The bands have bolts through them also. Just trailered it with the axle rotated and it is backing up great and trailers fine loaded down.
