shortlid
Derry, NH
I just bought a well made but home made 4X6 utility trailer to pull behind my Hond Accord sedan. The only issue is the leaf sprung beam axle is bent! Where can I get a 38" spring center 42" overall length axle? Have yet to find anything with thouse dimensions.
BarneyS
S.E. Lower Michigan
Moved to Tech Issues forum from Towing.
1995brave
San Antonio, TX
Did you check out Northern Tools?
Trailer parts
SoCalDesertRider
SanDiego, CA, USA
I think the website I saw alot of axles at was www.etrailerpart.com There may have been a '-' in there somewhere.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Trickewon
Lebanon, Pa
If it is not bent to bad take it to a weld shop and they can fix it.
Pappy, Two Grandkids & Their Dad Camping The Way It Was Meant To Be
F150 SuperCrew 5.4 V8 Wildwood LE 27BHSS
weasel4
Alberta
shortlid
How bad is it bent? If it has a slight upward arc to the axle, it's probably normal.
BTC
Everything in moderation, including Sobriety.
Gdetrailer
PA
Shortlid writes "The only issue is the leaf sprung beam axle is bent!"
As weasel4 states there SHOULD be a slight arc (or bend if you will) that goes up in the center of the axle when trailer is unloaded. This is needed for proper camber of the tires when the axle is loaded (the arc in the axle will flatten out when loaded).
You also can find replacement axles at locally at Tractor Supply or online at Etrailerpart.com (keep in mind the shipping WILL eat up any savings of buying online and returning could be a hassle on LARGE items).
alleghany nf camper
North West Penna
Tractor Supply
06 Chevy 2500HD reg cab
06 Chevy Trailblazer ext V8
02 Dutchman 29 Q Sport
Army Vet, German Wife, 1 Boy(10), 1 Girl (5), and a little Mutt Dog
shortlid
Derry, NH
Gdetrailer wrote: Shortlid writes "The only issue is the leaf sprung beam axle is bent!"
Nope it was backed into a rock or some thing bending it i the middle and toeing in the wheels. However Gdetrailer you give me a GREAT idea. It is a square beam axle with squared U bolts holding the axle to the springs. So I can u-bolt the axle turn it 45 degrees to where the bend is UP!! Then when I fully load the trailer it will flaten out the axle out for me!!
Cox89XJ
Tennessee
When I was a kid, I helped my dad straighten a utility trailer axle. We used a bottle jack and chain.
