RV.Net Open Roads Forum: Tech Issues: New Dometic Recall Initiated March 11, 2008
 > New Dometic Recall Initiated March 11, 2008
Page of 10
MELM
GA
Posted: 05/08/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to the members who have provided info on this new one.
Dometic has a new recall for refrigerators made between June 1, 2003 through September 30, 2006. Many of these are the same models as were in the older recall (Recall number 06E076000). (Technically, Dometic’s letter indicates an extension of the original, but NHTSA assigned a new Recall Number and the information is under that new number.)
Since it has a new NHTSA number, I’m starting a new thread on this one; but the actual work appears to be the same as in the first recall.
Text from the NHTSA website Recall 08E03200.
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
Recall Number: 08E032000
Summary:
DOMETIC HAS REPORTED A SAFETY RELATED DEFECT COVERING 745,574 TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN JUNE 1, 2003 AND SEPTEMBER 30, 2006, WITH SERIAL NOS. 320XXXXX THROUGH 352XXXXX; 401XXXXX THROUGH 452XXXXX; 501XXXXX THROUGH 552XXXXX; AND 601XXXXX THROUGH 639XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS REPLACEMENT EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL/MAY 2008. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Some more links:
Dometic Recall Site
Dometic letter of April 11, 2008
NHTSA Response letter of April 21, 2008.
And here is a link to the original recall thread: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
Edited to add a link to the original thread.
* This post was edited 05/09/08 08:43pm by MELM *
Chris Bryant
DeLand, Florida, USA
Posted: 05/08/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Mel!
Sometimes I feel like a mushroom .
-- Chris Bryant
My RV Service Blog
The RV.net Blog
A1B00902
Vancouver B.C CANADA
Posted: 05/08/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
SORRY
your date for the re call are wrong, it is from April 1997 to May 2003 as per the re call notice I got the other day, and I have my rig booked in for replacement next week, they are holding the parts for me
MIKE
JTMO
Novato, CA
Good Sam RV Club
Posted: 05/08/08 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
A1B00902 wrote:
SORRY
MIKE
It is an expansion of the current recall as stated.
"The recent expansion of this recall now includes the same two-door refrigerators, manufactured between June 2003 and September 2006."
Cedar Creek 27LRLS 7359 dry with extensive options/7700+ loaded.
2003 Expedition 5.4 FX4 with factory Tow 3.73 Bilstein shocks. GCVWR 14500, Tow rating with no cargo 8650
Equalizer Hitch, Prodigy, Barker Electric jack. Coachnet ERS
Rallies=13
My travel albums
Mike Schriber
San Diego, CA
Good Sam RV Club
Posted: 05/09/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Same band-aid fix right?
It would be nice if they actually replaced the parts that can cause the rupture rather than simply worrying about containing it.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
paztruck
San Diego, CA
Good Sam RV Club
Posted: 05/09/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yes they put a metal plate in to contain the fire if it starts. Got mine fixed today. If you are part of the new recall suggest you take the internet printout with you. The repair facility I got mine fixed at this morning knew nothing about the extended recall until they called Dometic. Now they are wise but it will help save the frustration if you bring proof.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
Dark Green HD Dmax
Central Tx
Posted: 05/09/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Why don't they address the root problem instead of just covering their butts with the fire hazzard containment sheetmetal afterthought fix. I just replaced my cooling unit,...guess what...the replacement is an exact copy of what i had.
MELM
GA
Posted: 05/09/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
heavyequipmentmover started a new thread. But I'm moving the post to this one and closing it - one thread is preferred. Mel
heavyequiptmentmover wrote:
I called Dometic today to confirm that my Dometic RM 2652 refer is included in the recent extention of recalls. (888-446-5157) Other than tell you your refer is one of the recalls,the young clerk at that number is not any help on details of the necessary work to comply with the recall.
Also called Dometic customer support 574-294-2511 thinking I would be able to get more information on the work necessary to accomplish the recall.The young man there was no more help then the previous young lady.Even though he said he was there to answer Tech questions,was not willing to give out info on the recall.
The NHTSA letter to Dometic of April 21,2008 stated that Dometic would install a secondary burner housing.I am not familiar with the nomenclature BURNER HOUSING.Is it referring to the cylindrical tube that surrounds the flue tube and electrical 115VAC heater?
If the recall installs a secondary burner housing within a burner housing,how does this effect the efficiency of the burner?
I have noticed that Dometic has installed a thermofuse on the cylindrical tube that surrounds the flue,whos location is in series with the 12+VDC to the Control Board.Is this Dometics means of killing power to the control board,to shut down burner incases where things get too hot within the cylindrical tube.Like if you have an uncontrolled fire?
B. C. S.
Boise ID.
Posted: 06/06/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I've taken mine in this past couple of weeks too. My refrig is documented/verified as being one affected by the recall.
Dometic was "by good faith, repairing and/or replacing the refrigerators." After April 1st, they no longer are replacing the entire refrigerator! The recall is ONLY for the Secondary burner housing.
After numerous calls to my RV dealership and Dometic, they still will not cover any of the charges. I got my trailer in 2002, been deployed for two years, had various orders off and on out of state, and they still will not cover my refrigerator. All because it is past the warranty of 3 years (no extended warranty documents).
But out of good faith, if you brought in your trailer prior to April 1st you were taken care of, now, I'm out of luck. All because they are not "required by law" to replace it. The recall is for the housing only.
My dealership says it will be cheaper to just buy a new refrigerator and have it installed (which will be over $1770.00). They say at least I'll get another 3 year warranty. BIG DEAL! It didn't help me last time....
I've filed a complaint with the NHTSA this morning. My next step is to contact my states Attorney General's office. I will be calling my dealership to see if they can replace it with a Norcold Refrigerator instead. I DO NOT want another Dometic ever again if I can help it. I would assume that a manufacturer that is aware of a defect (or even the possibility of one, to the extent they put out a recall) that they would take care of the consumer no matter what if they were affected. Apparently Dometic will not, even if it is a 1% probability.
Has anyone else felt this way or had this happen too??? I wish I had the time or felt comfortable to repare/replace the frig myself...
B.
2006 F350 SD/CC/LB Lariat 6.0 PSD
2002 Salem TT - T23LK
2006 Yamaha 2400is Generator
manley
georgia
Posted: 06/10/08 04:30am Link  |  Quote  |  Print  |  Notify Moderator
First, they performed the recall on mine.
1 year later, they replaced the cooling unit (after it went out).
Don't much figure that I can argue about it, on a 1997 model camper.
Signed: Happy camper.
2007 Chevrolet Silverado Z-71 4X4
5.3L Vortec, 3.73, Automatic, Hensley Arrow
2009 Keystone Cougar 29RLS
Page of 10
