RV.Net Open Roads Forum: Fire Hazard Appliance Recalls UPDATED NORCOLD INFO 11-20-2010
Open Roads Forum  >  Class A Motorhomes  >  Safety Issues & Recalls
 > Fire Hazard Appliance Recalls UPDATED NORCOLD INFO 11-20-2010
Page of 18
JohnnyT
On The Road
Posted: 05/08/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
For specific information;
NORCOLD RECALLS 11/20/2010
Fire Hazard - Appliance Recalls - Norcold, Samsung and more
Norcold Refrigerators------- Updated serial number coverage
Norcold Recall Information as of 2/13/2010
Samsung Microwave Ovens
Mr. Heater Heaters
First Alert Smoke & CO Detector Recall
Dometic Refrigerator Recall
New Dometic Recall Initiated March 11, 2008
* This post was last edited 11/20/10 04:19pm by JohnnyT *   View edit history
HappySimbas
San Jose, CA, USA
Posted: 08/21/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Johnny,
I just tried your links in this "Recall Corner". Unfortunately, all the links only take me to Good Sam's main forum web page, not to the specific product brands being recalled.
I am doing this from Japan (I am on a business trip here for a few days), but I don't believe that should cause a problem. Would you double check the links again to make sure they are still fresh?
BR,
Benjamin
Ben, Autumn, Nathan, and Joey
FMCA F348063
2005 Holiday Rambler Endeavor 40PDQ
2008 Honda CR-V EX Toad
Bus-Boy
Upstate NY
Posted: 08/23/08 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Same here, go back to Good Sam Club page.
JohnnyT
On The Road
Posted: 08/24/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
There were two that got messed up when Good Sam went to the new software.. I have fixed them.. The rest should have worked for you...
JohnnyT Moderator
Bus-Boy
Upstate NY
Posted: 08/25/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, that's a big help.
RayChez
Barstow, Ca. USA
Posted: 08/03/09 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
There is a new series of Cooling units on the Norcold 1200LRIM that are being recalled. I don't have the recall number because I am not where the letter was recieved, but I called Norcold and they told me where to take the coach. They changed some insulation and shield that goes around a pipe where the propane is in use. It also has a couple of wires. Don't know what they were for. Norcold paid for the labor and parts. No cost to me. Refrigerator was pulled out to make repairs. Maybe Johnny can update the latest recall or latest addition to the recall. I have the four door with ice maker 1200LRIM.
Lentz
Three Rivers, CA
Posted: 08/08/09 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Just had the recall fix done yesterday on my Norcold refer. Took about an hour to change out.
Had it done at Curt's RV Repair in LaGrande, OR.
Wayne
teaknme
VA
Posted: 09/29/09 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a 93 four winds back in July and had I not have seen this post I would not know about the recall, Thank you for the post! The Four Winds is in the shop getting the gas valve replaced! Thanks again!
93 Four Winds XL
safarisahara
SW Florida
Posted: 12/26/09 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Johnny..
We had the recall done two years ago. Since then we have been told that another recall is in the works. I called Norcold and they said that they were not aware of any new recalls. We had the Thermal Cut-off switch replaced via the recall in 6/08. What else is needed We also installed a special halon Fire Suppression system in the outside fridge compartmewnt. I was told that 1800 rigs burned up because of the Norcold units.. don't know how true this number is..but I personally know of several in my area.
Capt Ron
MRUSA
Wellington, FL
Posted: 02/22/10 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Ron, could you provide more info on the Halon fire extinguishing system? Sounds interesting.
Marc, Wellington FL
2013 Entegra Anthem 44SL
2010 Lincoln MKT toad
Unified Tow Brake
Pressure Pro Tire Monitor
Page of 18
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
