RV.Net Open Roads Forum: Fire Hazard Appliance Recalls UPDATED NORCOLD INFO 11-20-2010
Open Roads Forum  >  Class A Motorhomes  >  Safety Issues & Recalls
 > Fire Hazard Appliance Recalls UPDATED NORCOLD INFO 11-20-2010
Page of 13
uncleluap
iceland
Posted: 10/06/12 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Plumgrubby?
your post quote:
In my estimation, it's futile to keep toying with the Norcold refrigerator. The "fix" for fires is only activated when it senses an actual fire and does not prevent fires from occurring. It shuts down the unit only after a fire is detected!! I had it done to my Norcold as soon as I found out about it but then I realized that I had to keep my unit constantly on 9 to keep it cool at best.
this is terribley untrue and not even responsible posting. the recall sensor is designed to sences a hi operating temperature and shuts the fridge off so the possibility of fire is eliminated
If u had to keep it on 9 then yes there is a problem with your fridge
I have owned several 1200 fridges and have never used over 6 and norm is 5
MrDoneIt65
Golf Country NC
Posted: 10/06/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
What uncle said is true. The sensor would shut the fridge OFF before a fire occurred. But a true recall would have fixed the fire problem instead of just removing liability for Norcold. If the red light comes on in the sensor it has to be replaced. But that means your fridge overheated and tripped the sensor. So the fridge doesn't work.
It still comes down to the fact that instead of replacing the entire refridgerator it is cheaper and easier to replace the coils with the American made Amish coils and you won't need a sensor. And the fridge will cool on 5. End of problem. Why did the refrigerators catch on fire in the first place. No one knows, or their not saying. Were the cooling fans wired wrong like they were in mine? I didn't discover that problem until I replaced the coils.
'02 Southwind 37U towing '05 Chevy Colorado with Blue Ox tow bar and Brake Buddy. 8100 GM/Workhorse Chassis. Retired UAW-GM.
plumgrubby
Posted: 10/06/12 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I beg to differ but not start an argument. This is exactly what I was told by both the serviceman who put the retrofit on my unit and the Tech that came to look at my problem. Not all Norcolds have a problem but more do than don't.
My friend, feel fortunate that you don't have a problem but by the amount of people on here that DO have a problem it's worse than they are admitting to.
Good luck with your Norcold.... I now have the Amish cooling unit and love it to pieces, especially when I'm sleeping or have left the coach. Test your smoke detector regularly!!
Tompatfud
CT
Posted: 11/19/12 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Had the recall done twice and it shut down again so will have the third one installed. So much for quality
lanerd
Newport, OR
Posted: 04/28/13 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
If my 1210 ever gives me problems (and I've had the recalls done), it's history and a residential fridge will replace it.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
MrDoneIt65
Golf Country NC
Posted: 04/28/13 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the coils in my Norcold almost 3 years ago. It works great. No recall sensor necessary. And I would check the wiring connection for the cooling fans. I found out mine was wired backwards. Even though they are 12 volt pancake fans they will not work if the black wire and white wire are switched in the control panel on the back of the refrigerator. My original coils, with the recall sensor installed, blew out. Instead of buying a residential refrigerator and going through the problem of fit and finish to install it in the motorhome, I put in the Amish made coils. A whole lot cheaper than rebuilding the cabinet area around the fridge and it still works on propane.
Think about it.
DannyLeininger
TX USA
Posted: 05/22/13 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Ron
I'm a step ahead of you... DW wasn't feeling comfortable with all the issues surrounding Norcolds...so the Samsung's in and the Norcold is out! BTW if anyone lives or is passing near San Antonio I've got a Norcold 1200 looking for a new home... :-))
Danny Leininger
2007 Newmar Mountain Aire 4523
450 HP Cummins ISM on a Spartan K2 Chassis
2010 Explorer Eddie Bauer 4x4, nice
Good Sams, FMCA, Newmar Kountry Klub, AARP....
Page of 13
