rwenner
El Paso, TX
I love my Newmar coach, but I would never again purchase any coach with a Norcold product in it. (And I've bought 3 new DP's in the last 8 years). Just like in politics, the best way to vote is with your $$$$.
rwenner
El Paso, TX
Still waiting on Norcold to fix my upgrade (3rd Time)- - I guess if they wait long enough, we'll run out of fossil fuels and I won't need to get it "Upgraded".
Guess I'll look for some blocks of ice.
emzee
california
We have a NDR 1292, does that fall under the 1200 group, or do they put the actual numbers in there? Thanks!
trickyvic3
Raymond NH.
We got the upgrade done a few months ago, but now notice that it dosen't seem
to get as cold.
Has anyone else noticed this?
RayChez
Barstow, Ca. USA
The last recall from Norcold does not have anything to do as to how good your refrigerator cools. All it is is a heat sensor that will turn your refrigerator off if the pipes get too hot to prevent a fire.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
MrDoneIt65
Golf Country NC
Ain't an upgrade. It is a recall to stop the refrigerator from getting so hot it catches on fire. The so called upgrade blew out my coils. Can't call it an upgrade, it is a measure to prevent fires. Period.
Of course, since the refrigerator doesn't get so hot, maybe it ain't cooling as good.
'02 Southwind 37U towing '05 Chevy Colorado with Blue Ox tow bar and Brake Buddy. 8100 GM/Workhorse Chassis. Retired UAW-GM.
trickyvic3
Raymond NH.
I also now see a little red light glowing on a little black box behind
the access door.
MrDoneIt65
Golf Country NC
trickyvic3...your refrigerator isn't working. The Chinese sensor is bad, the refrigerator is shut down. It can't be reset, it needs to be replaced. Pray it isn't the coils blown. Mine were. If your refrigerator is out of warranty Norcold has no liability. If the coils are bad don't throw the refrigerator away and buy a new one, buy new coils. The Amish coils are heavier and no recall needed. Mine work better than new.
toughnut
usa
trickyvic3 wrote: We got the upgrade done a few months ago, but now notice that it dosen't seem
to get as cold.
The upgrade has ABSOLUTELY NO BEARING ON COOLING.Its not a upgrade anyhow its a hi-temp shut off system
hottubkid
SCHAUMBURG,IL
Just a note. I ended up putting two squirrel cage fans behind the refer. It is cooling lots better in fact I had to turn the numbers down two numbers. I ammed the output of the fans up and a total of 60 cfm. Sure works well for me
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
