PinkLeopard
South Lake Tahoe
loydt wrote: Dealer has my warranty parts in. Im scared to have it done because Im afraid it will make my fridge stop working!!!!!
Ours just came in also & we feel the same way. We full-time & don't want to be stuck out in the middle of nowhere without our fridge. I cannot believe there is not a class-action lawsuit forcing Norcold to replace the cooling units instead of the CYA fix!
Our Blog
Debby & Bill
on the adventure of our lives
"Man Plans & God Laughs"
2008 35' Southwind
2010 Subaru Forester toad
RayChez
Barstow, Ca. USA
I had mine done about a year ago and it is still working just fine. I would rather have the refrigerator shut down if something went wrong, then to have a fire and burn to death in the coach. It is a no brainer not to have it installed. All it is, is a safety device.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
rwenner
El Paso, TX
Fridge worked fine - - had the RECALL done today, Fridge doesn't work. Dealer wants to charge me for repairs.
Thanks Norcold
Snowsurfer
New Berlin
@MrDoneIt65, the fans should not come on after switching the wires. The thermal switch is set to turn the fans on when the temp at the switch reaches 130 degrees. I just replaced my cooling unit on our Norcold 1200 with a Amish built from rvcoolingunit.com. The install was easy, and the fridge works better than ever. I shot video and still pics of the whole process. Will be posting the finished video here soon.
Willie
edited 06/15/11 07:17pm by Snowsurfer *
1999 Monaco Diplomat 38A
2007 Jeep Wrangler toad
MrDoneIt65
Golf Country NC
Snowsurfer, that is exactly what happened. The wires were switched so the fans did not come on. By the time I figured out what the problem was the temperature had reached the necessary temperature so the fans came on. They go off when the temperature drops. If I gave the impression that the fans ran all the time it wasn't my intention. But it was my intention to make sure that everyone looks at the wiring schematic when reinstalling the wires into the control box. If they don't they could burn up another cooling unit because the cooling fans will never come on.
'02 Southwind 37U towing '05 Chevy Colorado with Blue Ox tow bar and Brake Buddy. 8100 GM/Workhorse Chassis. Retired UAW-GM.
2aroamin
Sioux Falls, SD
I had a Norcold 1200LR that was not on the recall list. We had a major fire with it today beware of this unit. The fire was all outside , we did not know it was going on. We never had a problem with it but I kept checking the recall list. I really like this unit
Jerry
Jerry & Mary
2004 DSDP 4009 UTB1000
TOAD 2002 Saturn LW300
Snowsurfer
New Berlin
Here is a how to video, in full HD, of my Norcold 1200, with a new Amish cooling unit from RV cooling unit warehouse. Any questions, e-mail me at
willie@fieldsbrothersconstruction.com.
http://www.youtube.com/watch?v=2x9quds5I6o
edited 07/02/11 05:05pm by Snowsurfer *
MrDoneIt65
Golf Country NC
Just make sure you download the installation instructions. I would also recommend you use the caulking they provide for the cooling fins on the bottom of the foam insert. They tell you to use the foam provided but once you bolt the new coils to the back of the fridge you can't get the tube for the foam in to fill any spaces. If you put the caulking in the lower area, which is what Norcold originally did, then you will have a better seal. And make sure you use the aluminum tape to seal the unit. Just roll it out to the desired length, loosen one end so you can stick it down and then peel the paper off as you place it over the foam and the back of the fridge. It works really well. In order to get the fridge out of the opening I used a motorcycle jack. Wrapped the steel wheels with tape so it wouldn't hurt my flooring and then pulled the fridge into the center of the kitchen covered the top with an old rug and jacked it up agains the ceiling to hold it secure while I removed the blow Norcold coils and replaced them with the Amish unit. One man, done in about 2 hours.
And check the wiring in the control box. Mine had been switched and the cooling fans didn't work. Also, do not disconnect the cooling fans from the wiring harness. You disconnect the wires at the top of the coils and leave the fans connected in the center of the black wire.
GM-Jayco36REQS
Ohio
rwenner wrote: Fridge worked fine - - had the RECALL done today, Fridge doesn't work. Dealer wants to charge me for repairs.
Thanks Norcold
We had the recall work done on the Norcold in our Jayco Pinnacle... now the fridge doesn't want to cool. Freezer works fine, but the fridge was still 80 deg after 4 hrs on AC. The freezer was 27 deg... any thoughts???
2011 Chevy 3500HD, DRW/CC, 4x4, Duramax TD, Curt 20K, Trifecta Cover
2011 Jayco Pinnacle 36REQS, MOR/ryde pin
2003 SVT Cobra Convertible, 16 lbs boost, Magnaflow cat-back, K&N CAI, MGW Shifter, 18" Bullet Wheels, Toyo Proxies
RayChez
Barstow, Ca. USA
GM-Jayco36REQS wrote: rwenner wrote: Fridge worked fine - - had the RECALL done today, Fridge doesn't work. Dealer wants to charge me for repairs.
Thanks Norcold
On a 2011 RV? It should have all kinds of warranty and I don't believe that Norcold would have recalled a 2011 refrigerator. It also sounds to me like probably who ever done the recall wiring must have left something disconnected. I think the dealer is wrong by trying to make you pay for the repairs. JMHO
