RV.Net Open Roads Forum: Beginning RVing: How to Prime the Water Pump?
Newest  |  Active  |  Popular  |  RVing FAQ  |  Blog Forum Rules  |  Forum Help and Support  |  Contact
 > How to Prime the Water Pump?
Kentucky Steve
Crestwood, Ky
Posted: 05/08/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
After dewinterizing, I ran my water pump for awhile, and it worked fine. I then hooked up to city water, and finished cleaning everything out.
When I refilled the water tank, unhooked the city water; the pump now constantly runs, but no water is being pumped. Even the hot water will not pump. I'm not even getting any air through the pipes.
How do I get the pump to prime, if that is what the problem is.
THANK YOU in advance!
Musicman
Wenatchee, WA
Posted: 05/08/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you might have a "selector valve" in the wrong position.
I have a valve that allows filling the tanks via the city water connection. If that is in the "fill" position, the pump will not pressurize the system.
Good luck !
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
eubank
Angel Fire, NM, USA
Posted: 05/08/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Humm. This sounds familiar. Three possibilities:
1. You've got a MAJOR leak downstream of the pump. If it were that bad, you'd probably see lots of water spreading. I assume this is not the case.
2. Water flow to the pump from the tank side is blocked. Check to make sure that water is making it as far as the pump by unscrewing the connection on the tank side and seeing that water is flowing. If it is now, check upstream.
3. This one is the hardest one: Water is making it to the pump from the tank (i.e., no blockage), but you have a small leak in the piping on that side. (This is what we confronted on our rig.) The leak can be so small that it'll hardly even leak water, but even a leak that small will, under vacuum from the pump, allow enough air to enter pipe so as to cause the pump not to start pulling water from the tank. The leak will almost surely be at some connection or another along the line.
Lynn
Good luck with it!
Lynn
I love New Mexico!
Ford 2000 X192.22 3X7 RFH
4:16:1 Muffler, Espresso 84DF2
Dr0M1 Valve, CC3AQ Special Mod
32NXC Adolf, AID Intake
Anybody able to decipher this stuff wins a prize!
othertonka
Stockton, CA
Posted: 05/08/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Did you hook up the city water, and open the tank fill valve to fill your fresh water tank? If so,after you disconnected the "City" water hose, did you shut off the tank fill valve? If not the pump will try to refill the fresh water tank and will run all the time. Close the valve and then try again. Open the Hot water faucet and it will take a little time to fill the water heater and when the water flows steady out of the hot water faucet, the water heater should be full and turn off all faucets and the pump should turn itself off.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Cheddarhead
Northern Wisconsin
Try working the valve for your wintering hose back and forth. Open the valve and let the pump suck some air and then close it while the pump is still running and it should break your vapor lock. I would try this before dismantling anything. I had the same issue last year and that was what worked for me. Good Luck!
2006 Chevy 2500HD EC/SB 4x4 Duramax/Allison
05 Jayco "Jayflight" 285RLS
Some of our trip Pics
skipnchar
Topeka Kansas USA
Posted: 05/08/08 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Are you by chance pumping any water out the city water connection? Did you leave the water tank bypass (used to put antifreeze in the water lines) open instead of closed? Are you sure there is water IN the fresh water tank?
gary355
manitoba
Posted: 05/08/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
IF YOU HAVE A SHURE FLOW PUMP IT IS A DEMAN PISTON STYLE PUMP AS LONG THERE IS NOT A CLOSED VALVE DOWN STREAM OF THE PUMP YOUR PUMP DIAPHRAMS ARE SHOT BUY ANOTHER PUMP $99.00
MNtundraRet
Bloomington, MN
Posted: 05/09/08 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Locate your water-pump. Check the strainer on the inlet side to make sure it is not plugged from any scale in the filter. They can be openned and cleaned. The inlet water line could be disconnected at this location to squirt some water into pump. The pump could need replacement if it is old. Pump-heads can be separately from whole unit, along with new strainers. It wouldn't hurt to remove and clean the strainers on each sink faucet. If they are blocked, they can contribute to getting lines primed with water. Normally these pumps are self priming and will work fine. Also confirm that you have water in your holding tank.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
Me&Margie
Stanwood, Wa.
Posted: 05/09/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Try this: Fill your fresh water tank, turn on pump, while pump is running open fresh water tank drain and let water drain for about 10-15 seconds. Don't ask me how or why this works, but it is what we have to do to ours every time we refill the tank!!??
Luck...........Marv
Marv
'07 Cardinal 31RKLE
'06 F-250 PSD 4X2 S/C, Hijacker, Line-X.
goin2themountains
Aztec, NM
Posted: 05/09/08 08:39am Link  |  Quote  |  Print  |  Notify Moderator
post deleted, 'cause I'm an idiot and didn't fully read OP's post.
* This post was edited 05/09/08 04:29pm by goin2themountains *
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
