tommy wilson
southern ca, usa
1996 newmar kountrystar spartan mountainmaster chassis. step will not extend. have found 5amp fuse in dash and 25 amp fuse in electric bay. both are good. cant find third fuse shown on kwikee wiring diagram? any suggestions where to look? fuse panel in bedroom shows all are good. none are labeled step. have looked in front generator comp and cant see any labelled step. tried shutting off all power and turning it back on. no good. getting ready to crawl under.
tommy wilson
1996 kountrystar dp
tommy wilson
southern ca, usa
found third fuse in electric bay. if no one knows of another fuse i guess i will crawl under tomorrow.
Wherever I happen to park
Crawl under, KEEP CLEAR OF STEP and have someone open the door.. OBSERVE LIGHT
If you see the light, Controller has power and is most likley working
Take hammer and gently tap the motor, About as you would a hard boiled egg
Do this 4 or 5 times and have partner open door again, Do it again if needed,
You might get lucky
If you do.. May I suggest service center
deandec
Sacramento, CA
Pass a magnet over the door switch. Works on my kwikee.
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
Gonnacall
WV
deandec wrote: Pass a magnet over the door switch. Works on my kwikee.
Also check your door switch to make sure it's good.
2001 Journey DL - Cat 330
Gonnacall wrote: \
If the little light under the steps goes on when the door is open, and off when the door is closed.... Switch good
tommy wilson
southern ca, usa
paid $466.00 to lamesa rv to replace control and motor.
