RV.Net Open Roads Forum: Tech Issues: Norcold won't start...
 > Norcold won't start...
kaagee
Burlington Ontario
Posted: 05/08/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
My Norcold N621 won't start....
I've cleaned the burner and jet..
I have ignition...and gas supply....
I can light it manually...runs long enough
to bring it to desired temp...when it reaches set temp..
it shuts off as it should..then the "F" trouble code
shows and will not relight on it's own..
Anyone out there have this problem before.
I'm leaving on a trip tomorrow..
Any help would be appreciated..
Thank You.. Ken
dougrainer
Carrolton
Posted: 05/09/08 06:11am Link  |  Quote  |  Print  |  Notify Moderator
The "F" means no flame. You light it manually, does that not indicate to you, that you have a problem with the gas lighting system????? Either the Spark Electrode or the Control board is defective. Doug
sdsdsd
Malvern,Pa
Posted: 05/09/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
If it indicated to him that was the problem he would not have asked! We are not all as smart as you !
steve
kaagee
Burlington Ontario
Posted: 05/09/08 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the support sdsdsd. LOL
I replaced the igniter...spark wasn't strong enough..
Now I'm smarter...
