RV.Net Open Roads Forum: Travel Trailers: ATTENTION ALL MEMBERS - NEW DOMETIC RECALL
 > ATTENTION ALL MEMBERS - NEW DOMETIC RECALL
Page of 11
scottsnider
Buena Park
Posted: 06/04/11 06:31pm Link  |  Print  |  Notify Moderator
inside refer.jpg This may not work, mac's and post pics are not the same as pc's, I hope this pic if it comes out shows a fix to the refer.
RaviAuto
jaipur
Posted: 10/22/11 12:54am Link  |  Print  |  Notify Moderator
I checked this link but it not open properly i will try later..
BarneyS
S.E. Lower Michigan
Posted: 10/22/11 08:17am Link  |  Print  |  Notify Moderator
It seems that the website has been taken down - probably due the fact that the recall has been going on since about 2007. You can check this thread for most of the information that was on the recall website. If you still have questions, I would call Dometic and ask.
Edit: this link should work.[emoticon]
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Islander1
Long Island
Posted: 05/02/12 04:17pm Link  |  Print  |  Notify Moderator
OP link is dead.
JJBIRISH
Butler, PA, USA
Posted: 05/06/12 09:53pm Link  |  Print  |  Notify Moderator
Link with some pictures…
click
Love my mass produced, entry level, built by Lazy American Workers, Hornet
AnEv942
CA
Posted: 05/08/12 01:33pm Link  |  Print  |  Notify Moderator
Pics from the link above-help to identify if your refer has had recall done- basically a safety thermal link is added to wiring near burner and a themal disk/button added to flue-if either sees high heat shuts off power to refer. Also added is sheet metel under, behind and in front of burner-to contain fire I assume should one start.
This shows the added thermal link in wiring and added thermo disk/button that shuts down power to refer..(added front sheet metal removed). Shows added bottom tray and metal surround in back.
And the front surrounding sheet metal (yours would be square, I loped of corner cause it was rubbing heater wires)
Mark
Our camper projects page
KookieD
Barnesville, Ohio
Posted: 09/09/12 06:35pm Link  |  Print  |  Notify Moderator
Just happened to log into site, been gone for quite some time, read something about recall on dometic refrig, what is the story on this?
BarneyS
S.E. Lower Michigan
Posted: 09/20/12 06:34pm Link  |  Print  |  Notify Moderator
Check my post above on 10/22/11 and then click on this link to read about it and put in your information.
Barney
falconman515
Fresno, CA.
Posted: 10/06/12 10:11pm Link  |  Print  |  Notify Moderator
Thanks so much for bringing this information to my attention with this sticky!
I just bought a used 1996 Fleetwood Prowler with a Dometic RM2652 fridge in it ... went to Dometics website and clicked on the recall info link, asked to enter model and serial and it came back saying "my fridge was affected by this recall"!
So how does this process work ... I call my local authorized service center that dometic had provided me a list and they just set and appt. for me to take the trailer in and it's all just done and taken of ... nothing out of my pocket correct?
What exactly is this issue?
Thanks so much for all the info you can provide on this for me.
1996 24' Fleetwood Prowler
Towed By ...
2011 GMC Sierra 1500 Z71 4X4 Crew Cab
falconman515
Fresno, CA.
Posted: 10/08/12 07:40pm Link  |  Print  |  Notify Moderator
Mark
So what exactly is it that I look for in this picture to know if this service has been completed?
I just bought this trailer and I would like to find out before I schedule an appt. with a service center if this has been done.
Thanks
Page of 11
