85AllegroSam
Madison, Al
My home type stud finder does not give a clue in my trailer as to where aluminum, or steel frame members are. There must be a trick to finding the frame members in our RV's so we can drill into structural points for hanging things on the walls.
Any tricks, or devices? My home type stud finder is an older one from Sears. Will the newer ones work for aluminum or steel etc? magnets do not work on the aluminum.
2008 Dutchmen Kodiak 27CDSL, 94 Dodge 4x4 Cummins, Trailer mods: Automatic switchover for Honda EU3000IS generator w/extension plug to back of truck. Propride 3P hitch Plan to do mods for camping in cold weather.
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
erobinson1
Bainbridge,Ga.
My Zircon will find metal studs. A quick check of their website says all models will detect metal studs. You might ought to pick up a newer model.Lowes and HD routinely sell models for about 20 bucks.
Dick_B
Palos Heights, IL USA
In the latest Duluth Trading flyer (www.duluthtrading.com) they have an item called Stud 4 Sure which is a powerful magnet that will find steel studs and/or screws and nails in drywall. It will probably not help find aluminum studs.
My rig has aluminum studs and after a rain the outline of the studs can be seen when looking at the outside fiberglass walls. It seems the drying rate is different for bare wall vs walls backed up with studs.
Hope some of this helps.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
ryanallie1
Magalia, Calif
Hi All.
There is a whole new genertion of stud finders on the market now. Yes, they have one, that can locate allumimn or metal wall studs. They also have one that can trace electrial wires and electrail conduetes also. Go Look at Lowes. I have seen them in the Tool Department. Good Luck. Happy Camping, Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
85AllegroSam
Madison, Al
Thanks all. Just needed to know i wasn't looking for a left handed monkey wrench or something like that. I will start shopping shortly and I will repost when I have found the finder of my dreams
85AllegroSam
Madison, Al
Forgot to mention that I am going to now be the nutcase that is always staring at the sides of the trailer after rains to see he can get a mental picture of of his frame
djevans
Tennessee
85AllegroSam wrote: Forgot to mention that I am going to now be the nutcase that is always staring at the sides of the trailer after rains to see he can get a mental picture of of his frame
85AllegroSam . . .
You usually can see the outline better when the vehicle is cold. (especially when frosted lightly) So you might not see them for a while!
They also won't help as accurately from the outside of the vehicle, if you're mounting something on the inside.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
85AllegroSam
Madison, Al
Hey djevans, who is talking about accuracy Right now I have no idea where any of my framing is located. One nice frosty morning I am going to have a whole better idea where to look when I get inside. I feel clever already, even if I didn't figure it out by myself.
Mikeyxx
Hamilton, Ontario
Can't you gently press along your walls until they won't flex? That's how I located mine. It was...flex...flex...less...less..none..more...more...flex..flex. Then I knew where that one was, and then I went 16" from there and found the next, and the next and....
