RV.Net Open Roads Forum: Fifth-Wheels: What tire pressure??
Newest  |  Active  |  Popular  |  RVing FAQ  |  Blog Forum Rules  |  Forum Help and Support  |  Contact
 > What tire pressure??
NorthernNeck,VA
Montross, Va.
Posted: 05/09/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced my old tires with 235/85 R16 Commerical TA's, but the dealer wasn't sure what pressure to inflate them to. He said most likely 75-80. My 5er is a King of the Road, Royal Villa, 36ft. What pressure should they be inflated to??
Thanks in advance.
Jimmy
Jimmy & Kathy
Northern Neck, VA.
2008 GMC
2005 King of the Road "Royal Villa" 34BW
tvman44
Southwest Louisiana
Posted: 05/09/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
The max rating of the tire so you can carry the max rated load which you are probably close to anyway.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
outdoorsman2007
Somewhere in the US
Look on the tire.
Jack_Diane_Freedom
Toronto Canada
Posted: 05/09/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
What load range are they? I have a 36ft 5er and mine take 110psi
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 05/09/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I agree. Also the max. pressure will also give you maximum fuel mileage & maximum stability. Tires not fully inflated heat up quicker & to higher temps & low pressure allows the potential for sway. My brother has a TT. He replaced his truck tires & the tire shop inflated the tires to a "comfortable ride" pressure. In addition, his trailer had sat over the winter & the tires were low. He came from Kentucky to Georgia to meet my wife & I. We followed him back to Ky & noticed that his rig was swaying all over the road. When we stopped for the night, we discussed the swaying. He said it had gotten worse since he replaced his truck tires. The next morning I added approx. 12 lbs of air to each truck tire to maximum pressure on tire sidewalls & did the same for the trailer using my compressor. The swaying stopped & he got an extra 25 miles on each tank of gas for the remainder of the trip.
juzplanekrazy
Huntington Beach Ca.
Posted: 05/09/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
"SEE TIRE" it's wrote on it, what max pressure is.
07' KZ New Vision ToyHauler 38SBx3
08' Ford Lariat F-350, 4x4, DRW Tow Boss, Nav, DVD +
20.5K Super 5th w/Super Rail kit
mowermech
Billings, MT
Posted: 05/09/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on your trailer, there is a data plate that gives the recommended tire size, load rating, and tire pressure, as well as the maximum GVW of the trailer.
Personally, I would use THAT recommended pressure. Yes, you can inflate to the max pressure shown on the tire, if you don't mind your tread wearing out in the center. Having tires over inflated also lessens available traction, due to the reduced footprint.
Once again, it is all about preference. I prefer for my tires to last the way they were designed to.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 272,000 Miles
'99 Monaco McKenzie 32' triple slide
'92 Caribou M-11KX truck camper.
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
lv2rom
Kansas City, Missouri
Posted: 05/09/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I don't suppose you would consider airing your tires according to the actual load you are expecting them to carry???....Brian
2005 F350 Dually -AFE air/MRSP exhaust/Bags/Bilsteins/Energy Susp.
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
smkettner
Southern CA
Posted: 05/09/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
If you installed oversize tires then you should weigh the trailer and refer to the manufacturer's inflation table.
If it is OEM size then run the max on the sidewall.
tjar66
Portland OR
Posted: 05/09/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
I run mine at max pressure indicated on the tire. I know how heavy my trailer is.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
