RV.Net Open Roads Forum: Tow Vehicles: 06 Dodge CTD air filter?
Search only in Tow Vehicles
 > 06 Dodge CTD air filter?
mking
Indianland,South Carolina
Posted: 05/09/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I purchased a air filter to replace the one in my truck,And it appears that the one in the T/V was the orginal.Anyway the new filter didn't have a dust cover on the bottom of the filter.My question is would the replacement filter be OK,and without the dust cover would this avoid the warranty?The orginal filter was a chrysler brand.The new filter is a Fram.
2006 Dodge Quad-Cab 2500 CTD,4;10 gears,pulling a Forestriver Flaggstaff 831qbss
camping man
Central Fla.
Posted: 05/09/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I haven't seen another brand with the extra filter yet. I've researched it to death, if you want a good filter for a decent price, pick up a NapaGold(Wix). My last Fram nearly got suck into my engine ,in about 3 weeks. It was because of the pleat design it had, instead of the air going thru, it was trying to suck all the pleats together, I knew something was wrong because my filter minder wasn't ever pulled over that far even with a year old filter in it.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
mking
Posted: 05/09/08 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply camping man.I'll take the fram back and get the NapaGold filter.I haven't drove it yet so they should take it back.
troll3193
SouthWest, MI USA
Posted: 05/09/08 11:40am Link  |  Quote  |  Print  |  Notify Moderator
I have been buying mine from Geno's Garage... They have all had the foam piece on the bottom..
only $12.95.....
http://www.genosgarage.com/prodinfo.asp?number=AF-26106
I don't wait for the filter minder to tell me to replace it. I actually change mine every oild change, so every 30k miles I buy four air filters and two fuel filters from Genos and I am set for a while...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
JustLabs
Washington State
Posted: 05/09/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Napa Golds as well.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 05/09/08 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Geno's Garage if you love your Dodge. Usually best price on the right oil filters, fuel filters, and air filters. Diesel need 2 things to run...air and fuel. In my opinion it is not a good idea to save a few cents on those filters.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
JIMNLIN
Big Cabin, OK
Posted: 05/09/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Fleetguard makes the filters for Mopar and Cummins. The Mopar comes with the foam added. The Cummins doesn't have the foam. I have always used the Cummins filters without the foam and I also have used Fram air filter. You will be just fine.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
2008Wildcat
PA
Posted: 05/09/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use an Amsoil Nanofiber dry drop in filter......works great and increases airflow, without the oily mess of some other replacements.
The HitchHikers
Gold Bar, WA
Posted: 05/09/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Other than my very first oil change(purchased from Cummins) I have purchased all my filters from Geno's Garage. The three previous filters had a loosely woven material for a prefilter and had a light coat of oil on it. The filter I just installed about 1,800 miles ago has a foam prefilter. I believe the first filters were Fleetguards and the current one is Mopar but I may have that backwards. In any case I change my air filter every 4th oil change which has been about 20,000 miles. I am going to extend my oil changes out to 6,000 miles based on OA results and this will change my air filter at about 24,000 mile intervals. I will use this interval unless something tells me I need to change sooner.
Steve and Gayle
2004.5 Dodge 3500 4X4, SRW, QC, SLT, LB, NV-5600, 3.73 AS, 325/600 Cummins
