RV.Net Open Roads Forum: Travel Trailers: Just replaced tires and have a question
 > Just replaced tires and have a question
Cool Canuck
Winnipeg, MB, Canada
Posted: 05/11/08 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
First. If we go to and investigate the rims we find that CT&W 14 inch rims are good for 1870 lbs @ 50 psi.
Second. Under inflation means under inflated for the load carried. As example, I have never ran max tire pressure in my truck. @80 psi it would jar your teeth out. I air the tires for the load carried which would be 65 psi front and back when towing my trailer.
With most trailers, the tires are minimal for the load carried therefore recommended running them at max allowable pressure. That being said, the same rules apply and the tires only need sufficient air pressure for the load.
Check most passenger cars. The tire pressure listed on the door post is usually less than the max tire pressure listed on the tire side wall. Running with the proper pressure for the load, puts maximum tread contact with the road.
You can run the tires @35 psi if you want. I would probably run them at 40-45 psi myself. That would give lots of excess capacity, better fuel mileage and help keep them from rolling off the rim it those tight turning back ups.
Each to his own, but I would prefer a higher capacity tire any day.
* This post was edited 05/12/08 07:40am by Cool Canuck *
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
mmanske
Baton Rouge La.
Posted: 05/11/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Something I have wondered about.....Why the #&!! would the PSI ratings be stamped on the inside of the rim? This is like putting the opening instructions on the inside of the package!
2005 Chevy 1500HD 6.0L w/3.73s
2006 Zinger ZT300BH
Cool Canuck
Posted: 05/12/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
From what I understand, they are not even stamped. At least mine aren't. They put a sticky label in there. Good luck finding that.
JJBIRISH
Butler, PA, USA
Posted: 05/12/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
you are correct it is a sticky label, not even a good sticky, one that can be easily removed...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Road Trip
Virginia
Posted: 05/12/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Michelin publishes a tire load/inflation chart/book.
It requires you weigh the trailer(preferrable each wheel) and then use the proper pressure.
My trailer owners manual has a recommended pressure. Having weighed each wheel I found this pressure more than adequate for the weight.
My aluminum wheels has the weight on the inside (cast numbers), the side that faces the brake drum.
Road Trip
NHguy
NH
Posted: 05/12/08 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
What you need is the load and inflation table for the 185R14 tires. I was able to find a max load of 1700 at 65 psi(but no table)for the Load range D's. But the wheels can only be trusted to 50 psi without further inspection. Still don't panic because the trailer only grosses to 4400 lbs. I am sure 50 psi will handle more than 1100 lbs. It is too bad you didn't check this stuff before hand, the original size tires would have carried a little more load. And if you'd gone ST20575R14 load range C they carry 1870 at 50 psi. But either way you are well able to carry the weight of that TT.
What is not so obvious to some of the posters in this thread is that load range varies with tire size. So a Load Range C of a bigger size carries more than a D of a smaller size. Some of the tires load capacities cross over, Example an LT2857516 D (8 ply) has the same capacity as an LT26575R16 E (10 ply).
Anyway those tires will do fine for carrying capacity, but don't take them in soft sand, they are so narrow they will cut into the sand and sink.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
bkwatson69
columbia,s.c. usa
Posted: 05/12/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget th Valve stems. When keystone sent me five new tires to replace the sorry Missions that Had came on the TT.(had three to have cords seperate within a year and a half. first one was within a year.) anyway, I mounted the new tires myself and replaced the valve stems with new ones I had bought from Advance Auto Parts. Had one tire leak down several months later due to the valve stem while sitting. Then last year on the way to Disney World had a tire leak down and blow out and leave the Darlington stripe all around the wheel well. Problem was the valve stem. I later noticed on the package for the valve stems that those were only rated to 60psi. I ended up replacing all the valve stems with the metal ones that bolt into the rim.(held in with a nut over the valve stem). These I think are good to 120psi.
'96 GMC Z71 X-cab(when I grow up I want to be a Duramax.)
2004 Keystone Cougar 294RLS, Equalizer Hitch
4aSong
Northwest Arizona
Posted: 05/13/08 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Thank you to all for the information provided as it has helped greatly. Further research has confirmed what Cool Canuck had mentioned. I have some additional research to do but for now I have decided to run them at 45psi which seems to be acceptable (It looks like the 14x5.5JJ rims will support the pressure) based on the weight of the trailer (3300lbs. dry) and with carrying capacity for a total of 4400lbs.
Mike and Nancy
Tundra TRD V8 4WD
Prowler 20' Lite ( The Kramalot Inn )
EU2000i * Prodigy * McKesh * Trek
NHguy
NH
Posted: 05/13/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I apologize, but I under rated the tire. I am at work on break now and a new catalog came acros the desk. 185R14 C's by Kumho can handle 1874 lbs at 65 PSI. So you are definitely OK. Good Luck.
