RV.Net Open Roads Forum: Tech Issues: GGGGGRRRRRRR!!!! *^$%!@%& New holding tank valve
 > GGGGGRRRRRRR!!!! *^$%!@%& New holding tank valve
GrammaAnn
Benbrook, Texas
Posted: 05/09/08 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
The holding tank slide valves on the MH were leaking just slightly. Dates on them were 1987, so I guess they needed replacing anyway.
Sooooo!!! I get replacements - take off old ones - get the black water new one on, but can not get the gray water one on. the configuration is the standard "Y". they are so tight I can not get the second valve in with out the rubber gasket getting caught. It is like I need something to hold the tank exits apart untill the slide valve in in place, the release. THIS OLD WOMAN IS REALLY OLD SOME DAYS!
HELP!! any suggestions????
Gramma Ann
The Texas Gypsy
New to us - 1988 Shasta 32ft with full handicap accessibility. Move over world Gramma and Grampa are on the road!!
One OLD Hubby, Logan the dog, and Baby the cat ( both left over from the granddaughter !!)
1995brave
San Antonio, TX
Posted: 05/09/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have two gray and one black valve and had to remove the screws for all three just to replace the broken gray valve. Once loose i had to pull on the dump assy to get the old one out and the new one in.
sh410
Northwest
Posted: 05/09/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem. I loosend the back valve screws, then losely put the screws into the gray vavle, then tighten all until it all fit. Or you can put in the gray valve first, then the black valve so that you can jiggle things around. I hope you have success
dapark
SLC, UT
Posted: 05/09/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I found on mine that if I left the valve in place about 1/2 inch and slid the new one in it would clear and I didn't have to hold them apart while trying to put new one in. If you can somehow get your old grey water valve in place enought to hold the gap open, I believe that will work for you. Good luck
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
