yudamann
Outer Banks NC
Both the standard Maxxair and the Maxxair II vent covers are not recommended for use w/ the popular Fantastic Fan. They recommend the Fan Mate which is about twice the cost. The Fan Mate also appears due to its design to perhaps hinder air flow from natural convection, i.e. when the vent is open but the fan is not running. Are there any owners out there that have experience with either model used w/ Fantastic Fan that can share the love?
yudamann
Outer Banks NC
2005 Allegro Bus 38TGP
2004 Acura MDX toad
Brakemaster toad brakes
"We need more fools to test fool-proof equipment"
dgo1369
Georgetown, TX, US
Look at the MaxxAir 800. It works well with the vent/fan I have in the bathroom.
Dennis Osha
tomousecap
East Moline, IL
We have the standard Maxair on all of our Fantastic Fan vents and they work just fine. Only mod I did was to remove the un-necessary way too fine mesh screen they put in the cover and replace it with 1/4" mesh wire to keep the hornets out from under the cover. The fine mesh screen restricts the air flow too much.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2005 Saturn Vue V6 AT FWD Toad - Love it!
"www.Scavenger.us" Power Exh. Installed.
jchonroad
South Berwick, ME
We have a Fanmate and it works great. It was designed for use with the Fantastic fans. There's no problem with natural convection, nor do we find any problem (air restriction) with the fine mesh screen that it comes with. Air flow is fine.
JMNSHO (LOL)
John
John '46
Joyce '46 (DW)
GOOD SAM LIFE MEMBERS
Heidie '00 (13 lb."Guard Dog")
'05 Winnebago Voyage 35A
'03 Cavalier Toad w/Sterling Aluminum Tow Bar & Brake Buddy
Also: '96 Coleman Yukon behind a '03 GMC Sonoma with a Prodigy Controller
zmotorsports
Utah
I am running the standard MaxxAir units on our coach with no problems at all. Mike.
Mike & Chrystal (F315002)
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
1996 Jeep Grand Cherokee toad
Lt46
Cape Cod, Ma.
I'm using one of each. Standard over the bathroom fan and FanMate over the Fantastic Fan. No problems with air movement, at any time.
Peter & Dawn
97 Winnebago Adventurer 37RW
91 R2500,454 Chevy Suburban
96 Prowler 27X SOLD
Yamaha EF2800I
IAFF L-792
BaldyD1
Central Florida area
Seldom, if at all, have the Fantastic Fans on more than 1 to 2 spots above the very slowest speed and do not believe either the Fan Mate or MaxAir/MaxAir II to be so restrictive as to cause any damage to the Fantastic Fan. Also, believe neither of the three will hinder natural convection.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
Deen
Vancouver, WA
BaldyD1 wrote: Seldom, if at all, have the Fantastic Fans on more than 1 to 2 spots above the very slowest speed and do not believe either the Fan Mate or MaxAir/MaxAir II to be so restrictive as to cause any damage to the Fantastic Fan. Also, believe neither of the three will hinder natural convection. Fantastic Vent says that vent covers should not be used on any of their vents due to flow restriction when the fan is on high. I haven't put them on our present DSDP, with two Fantastic Fans. Did have them on our 2000 DSDP with two Fantastic Fans also. On it we couldn't use the high flow model due to clearance with the shower skylight. So I used the small unit, couldn't really tell any difference.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'97 Grand Cherokee/4 down
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Daveinet
il
I use the standard MaxxAir and it does restrict how for the vent opens and does limit the air flow slightly. Not sure why that would be a problem. Any time you restrict the flow on a fan, it reduces the load anyway.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
lyle_47250
madison indiana usa
I thought the problem was the height of the lid when raised all the way? With the auto raise there is no way to stop it until it get all the way up.
Lyle & Ginger and the 82 Revcon
