RV.Net Open Roads Forum: Tech Issues: Digital display
 > Digital display
gouldc
Edmonton, Alberta Canada
Posted: 05/09/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys,
I'm looking for an interim solution while I wait on purchasing a good monitor. Can anyone suggest a digital gauge(s) for monitoring voltage and amperage? One device that displays both numbers would be ideal, however, they'll be mounted in the battery compartment so appearance isn't too important.
Seems like digital voltage displays are easy to find, it's finding an affordable amperage display thats posing a problem. Spending $80 - $100 on a gauge makes no sense when $140 will get a good all around monitor system. I suppose that an analog amperage meter would be fine as it's precise voltage readings that are needed.
Thoughts would be appreciated.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
Wherever I happen to park
Posted: 05/09/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
There are several digital battery monitors.. One of the best is the LINK system, I believe it's made by Xantrex, monitors amperage, voltage, state of charge (Estimated) battery condition and more
http://www.xantrex.com/web/id/237/p/1/pt/5/product.asp
Have two banks of batteries to monitor... Try the LINK-20 (like to if from the above page)
smkettner
Posted: 05/09/08 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a digital panel meter to know when to start the generator.
Then I bought a Blue Sea analog ammeter to know when to shut off the generator.
If you are going to eventually buy a battery monitor you may as well just do that now.
gouldc
Posted: 05/09/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
That's the answer I'm coming to. I thought buying a voltage and amperage meter might be a cheap interim solution but pricing just doesn't make sense to do so.
nbounder
Arizona mountains
Posted: 05/09/08 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you just want a cheesey meter till later on, here's a digital VM that appears to work just fine, for less than $20. They are also available at camping World, in the store, in the electrical section. Checkout http://www.rvtoyoutlet.com/p-RVST558167.html, they might still carry them.
Joe
Rob & Kasey
Vermont
Posted: 05/10/08 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Be sure to also check out the Trimetric 2020 from Bogart Engineering. I have been very pleased with it's performance and functionality for 8 years now.
2008 Dodge RAM 1500 SLT Quad Hemi
2006 Forest River Surveyor SV-235RS
Running Gear: Prodigy and Equal-i-zer 10K
Power: Yamaha EF2400i, BP-375, SolarBoost 2000e, TriMetric 2020, 4xUB12750 AGMs, Prosine 2.0
Other: TopPopRails, LevelAirs
Staff: DW, DS, DD
gouldc
Posted: 05/12/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I like the cost and functionality of the Trimetric but the looks don't gear well for me and a permanent install.
 > Digital display
