scout3399
raleigh nc
hi new to form I have read most of the posting back fot the last year and have learn a lot. thank
on monday I drop off my brand new 2008 290 bh passport to get some problem fix one was the gray black tank reading .they would read zero then the next time full then zero agan. got a call today and they said the back tank was clog. I have only been camping 2 time i have all way let it get 3/4 full or fill it to 3/4 before i dump it. so now they want ot charge me to unclog it. i find it funny because. i dump it no problem the week before.
what would you do
their was one other problem the out side stove one of the burners then it gets hot you can not turn it off has this happen to any one else
jf504mp
Indiana
I can only relate to you stove knob by comparing it to my gas grill. It too gets hot and I have trouble turning the knob. I am not sure why this happens but I know I would want it fixed in my camper.
As for the tank indicators, mine worked fine last season but I am having doubts about it this season. I tend to not fill it enough to get a proper reading. As for your tank being clogged, if it empties at the dump station I would think it was ok. I recently added a clear section to my dump line. (gross, I know) but I need to be able to tell it is emptying without lifting the hose out of the dump station tank. Believe me, this way is better, if there is a better. LOL
old guy
Oregon (pronounced Or e gun)
buy a tornado or a quickie flush , get it installed and you can rinse the tank out each time you dump.you will never have a clog again.
USAFBILL
Alabama
Maybe the plastic plug they drilled out when they installed it fell into the tank and the factory just let it float around until it clogged the drain.
skipnchar
Topeka Kansas USA
Best advice I can give you about the black tank is to use a LOT more water. If it was clogged after only two uses then it's pretty much a given than you were NOT using enough water when flushing. First of all you should always START with 3 or 4 gallons of water in the tank before using it, along with the tank chemical of your choice (they all work so find one you like) then use at least two bowls of water each flush. You were doing WELL to make sure it was 2/3 full before dumping but it ALSO has to be full of a lot of liquid to flush out the solids.
I had a pop up that had an outside stove but it was the same stove used inside and never had a problem with knobs getting hot so I can't help there except to say it shouldn't do that (but you knew that).
Good luck / Skip
Hornet28BHDS
Parker, PA
Those sensors are known to be unreliable.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
scout3399
raleigh nc
thanks for the reply
got back from the dealer the gray and black tank where label wrong so that why they thought their was a clog in the black tank. their was alot of miss understanding at the dealer on other problems. I had to show the tech all the problems they would get address hopefully.
thank again
