RV.Net Open Roads Forum: Fifth-Wheels: Reese 16K Hitch Issue...Locking Bar Release?
 > Reese 16K Hitch Issue...Locking Bar Release?
R-affair
Coastal NC & The Western Slope
Posted: 05/09/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
On our Reese, from time to time when unhitching the locking bar hangs up & requires 2 of us to pull it out...DW "rocking" the truck in forward/reverse & me trying to pull it out. Level or not...angled or not...There doesn't seem to be a pattern. And yes, the safety catch is up!
I've looked at it from all angles & can't find anything amiss.
Anybody had such a problem or got any suggestions?
Help/ideas/suggestions appreciated!
MHO...Your results may vary!
Dick, Jeanette, & Rosie
'06 F-350 Lariat SRW SC 6.0 3.73 FX4 Auto LWB Truxedo
'06 KZ Escalade 36KSB
LadyRVer
Posted: 05/09/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, same thing happened to me the first time I tried to unhitch the Reese,
16K Slider. Found out, that after jacks are extended, just put truck in reverse, let foot off brake and that released just enough tension to pull handle. Maybe a little white grease would help, also, or whatever you use for lubricant. Never had a problem after that first time. After the first hour of trying to pull handle, thought I might have to tow that fifth-wheel everywhere.
trnfla
Tampa
Posted: 05/09/08 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
That would be a site to see...
Have a great time camping,
Terry
Please visit my Photos and Blog NiceCamps.com
New (2 me) 2004 Winnie 31C
2006 Expedition EB, replaced by scooter and 2008 Mazda 3
Had 2007 Zeppelin EZ190, Prodigy, Equalizer
CactusJohn
Scottsdale, AZ
Posted: 05/09/08 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem the first few times I used my 16K. Sometimes it would open with almost no effort, other times it wouldn't. I called Reese and was told that the jaws are designed to stay shut if there is any forward pressure on them. I was told to chock the 5er tires, put the truck in reverse, lightly touch the gas, and then put on the brake. This takes the forward pressure off and allows the jaws to open easily every time. I've never had another problem since that conversation. BTW, Reese also said that taking weight off the hitch by lowering the landing gear has nothing to do with opening the jaws--it’s all about relieving the forward pressure.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
R-affair
Posted: 05/09/08 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Cactus John...That's exactly the procedure we follow everytime, but...?
Cool Canuck
Winnipeg, MB, Canada
Posted: 05/09/08 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
You don't mention whether it is a rocker or not. If not any twisting between the truck and the trailer can make it difficult to release. Otherwise, I find placing the truck in neutral and letting off the brake usually releases any fore/aft strain. Just remember to put it in park after.
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
bobdeb
Grovetown Ga
Posted: 05/10/08 02:43am Link  |  Quote  |  Print  |  Notify Moderator
Have a 16K but never had the problem. Good info though and will file it away just in case.
PackerBacker
Montreal, Quebec,Canada
Posted: 05/10/08 05:40am Link  |  Quote  |  Print  |  Notify Moderator
LadyRVer wrote:
.... Found out, that after jacks are extended, just put truck in reverse, let foot off brake and that released just enough tension to pull handle. Maybe a little white grease would help, also, or whatever you use for lubricant. Never had a problem after that first time.
Exactly ... I've never had a problem either, you need to take the pressure off the jaws.
Eric
2004 Wildcat 27RL, Honda EU-2000i.
2003 Dodge Ram 2500 Hemi, 3.73, Reese 16K, Prodigy,long box, Line-X,
Good Sam's - FQCC/Camping Quebec
My Photos
bayoubengal
amite, la., usa
Posted: 05/10/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
We have this problem everytime, we have to back up slightly to relieve pressure. We have owned this hitch for 7 years. The other day we took our camper to the dealer for work, and as I was trying to pull the handle, it snapped in two. Thank goodness we were at the dealer, they gave us a new handle.
'02 2500HD, 8.1,Alli,4.10 Rear Axle
'08 31RKLE Cardinal
John3872
Iowa
Posted: 05/10/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I just has that problem, last weekend. I finally pulled the lever hard enough for it to release. Once I did that, the truck rolled back a couple of inches. From that I figured that I had the too much pressure against the jaws. From now on, Once I have the chocks in place, I will bad up a bit and unhook.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
