RV.Net Open Roads Forum: Fifth-Wheels: Damp carpet
 > Damp carpet
dennislanier
Georgia
Posted: 05/10/08 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I have a problem I hope someone can help me with. I have a Montana Mountaineer 307 RKD (rear kitchen). This morning I discovered that the carpet in the kitchen area is damp. The slides have been in since our last trip about 3 weeks ago. I checked under the cabinets for plumbing leaks, and the refrigerator also. All dry. The carpet that is wet is the carpet that is underneath the slideout when the slide is in. I checked the roof and did not see any problems there, and also checked under the slideout, which was also dry. I have no idea where the water came from. Does anyone have any suggestions at this point, before I take it back to the dealer, which I wanted to avoid if possible. Any info appreciated.
jason_rving
North Georgia
Posted: 05/10/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Is your unit sitting level? Even with the slides in, Rain can follow the slide channel and get in sometimes if not level.
Another thought, was it raining when you put your slides in 3 weeks ago?
Jason and family
2004 Cedar Creek 31LBHBS
2004 2500HD Silverado CC LT LLY Duramax/Allison 4x4
48 Gal Aux Fuel Tank - 74 total gal cap.
Husky 16K, Kipor 3500ti Generator
Prodigy, Timbrens, 285 Goodyears, Rhino Lined,
Cobra 75WXST with Firestik
donn0128
Pronounced Ore-gun
Posted: 05/10/08 08:59am Link  |  Quote  |  Print  |  Notify Moderator
How about plane old humidity? Do you run a dehumidifier when parked?
Donn
Cool Canuck
Winnipeg, MB, Canada
Posted: 05/10/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes those things are hard to track down. I had a poor seal around my fresh water intake. Any rain would run in there, down the piping, across the floor under the cabinets finally making it to the kitchen carpet. It appeared that the slide was leaking somewhere around the rear corner. That of course was not the case, but drove me crazy trying to find the culprit.
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
hendersonb
Fairfield, PA
Posted: 05/10/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Our Montana 3400RL had a wet carpet problem as well. It turned out to be a leak in the hose that connects the water pump to the water pipe system. The leak was a slow drip on an exposed area of the OSB sub-floor in the basement area(behind a plastic panel). Over time the water was wicking along the sub-floor between the vinyl and OSB to the carpet well over ten feet away. The water was also collecting in the area below the sub-floor in the arctic package area. By the time we saw water in the carpet area a lot of damage was done to to the OSB and insulation in the arctic package. Thankfully the unit was still under warranty.
Robert
* This post was edited 05/10/08 10:15am by hendersonb *
2008 Ford F350 Super Duty 6.4 PSD
2008 Montana 3400RL
rwmmdj
Georgia
Posted: 05/10/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
We had a similar problem and it was a bad slide gasket. Hopefully all better now, DH is picking the TT up from the dealer as we speak!
lambchop
WI
Posted: 05/10/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2008 Montana Mountaineer also. Same leak in kitchen by the refrigerator. Ours happened while driving in the rain. The dealer supposedly adjusted the the slide in, because it wasn't sealing right.
Lambchop
2008 33 ft. Montana 5th wheel
2000 3/4T Chevrolet Truck 6.0L 4:10
dennislanier
Georgia
Posted: 05/10/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Lambchop
This would be my guess right now. If it rains tonight and the carpet is wet tomorrow, at least I will have an idea for the dealer to check.
Thanks for everyone's input.
lambchop
WI
Posted: 05/11/08 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Dennis,Go Here:
to the Montana forum & post your problem. It's a very helpfull forum.
Lambchop
Kejsj30
Portland, Oregon
Posted: 05/11/08 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
We had the same problem with a Keystone Raptor and it turned out the slide needed to be adjusted. It would only leak with the slide in. In ours, the wet carpet caused the particle board moldings around the slide to swell. Keystone replaced under warranty.
2008 Chevy Silverado 2500HD
2008 Keystone Raptor 3712TS
2000 Bayliner 2855 Sierra SunBridge Boat (SOLD)
2007 Raptor 700R
2007 YZF 450RSE
2008 Raptor 700RSE
 > Damp carpet
