Daveinet
il
Unless you get a really small Class C, I don't think the class C will be any more maneuverable. Most class Cs are still wide bodies and 30 feet, not all that different from as a class A. I think those who believe a class C is so much more maneuverable is more of a perception than reality. You sacrifice cab space, leg room, and handling. Also consider that most class Cs target a less expensive demographic and so they typically not built as solid as a class A.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
Deen
Vancouver, WA
Have had TT's, one Type B (1988 bought new), one Type C (1997, new) and three A's (also all new with 2 being factory ordered), guess which we prefer?
The C usually has more sleeping capacity, but the A's are more livable, but with a family I'd go with a C and get the overhead bunk rather than an entertainment center (which is what our C had). Could and did sleep one small child up there but ... was cramped for any more.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'97 Grand Cherokee/4 down
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
MeanderMan
Fulltiming Somewhere
Be careful of the CCC with a class C - anything 30' or over with a couple of slides will probably have a very low CCC. I looked at a Jayco a while back that only had 385 lbs. Personally, I think you're better off in all aspects with an "A" and the price difference isn't that significant.
Happily Fulltiming Somewhere
Our RV Blog
JCWWBT
Georgia
Awesome feedback so far, thank you!!!
I think I will post in the Class C forum just to get their opinions too. I guess it boils down to a matter of preference, as well as what will fit our family comfortably.
1996 Itasca Suncruiser 37RW
TDInewguy
Minneapolis, MN
I've got 2 kids - almost 3 yo boy and a 4 month old. I'm not really even considering a Class C - as they are not very "roomy" feeling inside and it's not as pleasureable to drive. With the A you have the huge windshield that makes for a nice open feel. The cargo capacity is much better...
As for one to look at - if you want a diesel in your pricerange I have been looking at the 1999 Winnebago Adventurer 34V - it's a 34' long and has the queen bed, the sofa bed and the dinette bed. The bathroom has a small tub and I have found several in the mid $40K range.
SSSStefan
2006 Chev 2500HD - Crew Cab D/A
2005 VW Passat TDI wagon - tow vehicle for the pup!
2005 Fleetwood Allegiance
The most important thing you will ever do - www.claybe.com
SRDJ
Salt Lake City
JCWWBT wrote: Awesome feedback so far, thank you!!!
I have had both and each has their own good and bad points.
See if you can rent a Class C and a Class A in your price range. Spend at least a week in each one to really get the feel for how it might be to drive and "live" in them for a while. The longer you can stay in them the better to get a real good idea. I weekend is really not long enough especially if the weather is great as you will be outside most of that time and may not get a real good idea of what it might be like if the weather is bad for a few days straight.
The A just worked out better for our life style and RVing desires as we tend to take fewer but much longer trips at a time so having some "getting away" space helps a lot.
Good luck and take your time....don't buy less than you need or more than you can afford.
2008 42' Tiffin Allegro Bus, Xantrex RS3000 Pure Sine inverter, Garmin 2730 GPS, Cobra CB, Toad-2001 Acura MDX, Blue Ox base, Blue Ox Alexus LX towbar, SMI Silent Partner.
Wayne Dohnal
Banks, OR.
After looking at countless units over a couple of years and renting a 31 foot class C, I ended up preferring an equal-length class A over a class C on a Ford or Chevy/Workhorse chassis. The class A isn't any bigger outside, but has more room inside, bigger tanks, better visibility, generally doesn't cost any more, and is more comfortable to drive. We decided to go smaller with a Sprinter-based class C, but if we has gone with a 30-footer, it would have been an A.
2009 Fleetwood Icon 24A
EU2000i generator
driveby
Vancouver BC Canada
We've done both. Trust me, on a rainy day with kids you want the space of an A with a slide out. C's are just too small for 3 young kids on a long rainy day. We only have 2 but you can see we have an A.
Tanks are bigger too, more water (in and out )
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
JCWWBT
Georgia
Thank you! I think we are leaning toward the A, did I mention my 3 and 4 year olds are boys??? need space with those two. LOL
Again I appreciate you taking your time to answer and give your input.
69RoadRunner
VA
If you have 3 and 4 year olds, look at the bunkbed models. You can put the kids to bed and still have the living area available.
I have an almost 2 year old and a 4 year old, so I ordered a bunkbed Newmar Ventana. I went with Newmar because it was the only one with bunkbeds, enough towing capacity to pull my Road Runner on a trailer and I could afford it.
If you don't need to tow over 5000 pounds, then there are several options of Class As with bunkbeds.
Do a search in the Class A forum for bunkbeds.
09 Newmar Ventana 3942
